April 16, 2019, 22:53 |
axisymmetric burner weird temp contour
Abdulhadi Odeh
hi,
I am creating an asymmetric model for a diffusion burner, for now I setup up the model as non reacting and all velocity inlet BCs at T=290K , However when i run it , i get this temperature contour which i dont expect since all T=290 for air and multi component gas inlets , I have pressure outlets as extrapolated. Any advice would be greatly appreciated. I dont get it why the temperature rises at pressure outlet. I am using K-epsilon standard model (segregated flow) and you can also find a photo for my mesh. |
April 17, 2019, 00:19 |
Steve
Rep Power: 8 |
'asymmetric' <- you mean axisymmetric right? Can you show velocity, pressure profile and residual plot also? Last edited by steve lee; April 17, 2019 at 02:05. |
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour | Caster_Troy | FLUENT | 1 | December 7, 2017 06:19 |
Pressure-projection scheme for a lid-driven cavity | kopaka | Main CFD Forum | 12 | November 18, 2017 11:10 |
temp contour lines are not continuous at the interface of 2 zone!! [PLEASE HELP] | Hadi Khabbaz | FLUENT | 5 | March 8, 2016 19:10 |
Relation Reynolds number and Temp Distribution | Ledeeb | Main CFD Forum | 0 | March 4, 2015 03:41 |
Analysis of Propane Burner Designs | yorzaxt | Main CFD Forum | 0 | July 14, 2010 12:13 |
