May 4, 2019, 06:33 |
Conformal vs non conformal mesh results
Bharat
Using best mesh standards/parameters. 1) Did anyone tried to compare heat transfer results for conformal and non conformal mesh. if yes, what was the geometry/part. 2) How are the results varying. 3) Does non conformal mesh correlates with test data (or any closer match). it is a best practice to go with conformal mesh for better results, but, whats the actual or one on one difference foe mesh used?
chapter 3: -crossing the threshold- |
May 7, 2019, 04:30 |
Steve
Rep Power: 8 |
I have a experience the comparing. Conformal mesh means poly and non-conformal mesh mean trimmed right? as i remember, result was almost the same. but not exactly.. heat transfer result is the same. but flow result.. i got quite different result. i recommand trimmed mesh even though it is not conformal. Last edited by steve lee; May 7, 2019 at 20:29. |
May 7, 2019, 10:08 |
Lucky
Rep Power: 66 |
For a non-conformal mesh, you can generally satisfy the energy balance over volumes.
But if you want to match detailed temperature data, they you might want a conformal mesh. conformal mesh means that the mean on both sides of the fluid|solid interface are the same (i.e. one continuous mesh). |
May 7, 2019, 20:27 |
Steve
Rep Power: 8 |
Yes, but in CCM+ it is impossible to make conformal mesh using trimmed mesh.
I expect that Bharatt is asking trimmed non-conformal mesh vs poly conformal mesh.. |
September 1, 2020, 18:11 |
Farshad Rezaei
Hello, can you please explain how I can set non-conformal interface?
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ANSYS Meshing] Sweep mesh results in extreme aspect ratio | Highflower | ANSYS Meshing & Geometry | 4 | January 12, 2016 16:40 |
[ANSYS Meshing] Conformal mesh with mullti-part | JL_silencer | ANSYS Meshing & Geometry | 0 | November 26, 2015 05:18 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
