Freezing Velocity Flow Field
Old   October 24, 2019, 09:27
Default Freezing Velocity Flow Field
Pierce
PierceH is on a distinguished road
I want to be able to freeze the velocity flow-field while still calculating the pressure for these velocity conditions on STAR CCM+. In my inquiry, one of the developers mentioned the 'Great Source Method' however no documentation is available on this matte. I was hoping someone would have experience maintaining a velocity flow-field while calculating the Pressure.
Thank you.
PierceH is offline   Reply With Quote
Old   October 25, 2019, 07:11
Question
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Thank you.
Isn't that velocity and pressure fields inter-dependent ? (from Navier Stoke's Momentum equation)
How does this works exactly?
ashokac7 is offline   Reply With Quote
Old   October 25, 2019, 15:46
Pierce
So I'm essentially wanting to solve the inviscid pressure for a viscous flowfield. The pressure fields are coupled. If you set an appropriate momentum source term you can recover the desired velocity field.
Old   October 28, 2019, 17:20
Pierce
Essentially the idea is a source term can be added to the RHS of the momentum equation. You make this quantity so much larger than the rest of the terms so that it works on solving this rather than the rest of the equation you have.
Accuracy of the velocity field in a low speed wind tunnel? hob Main CFD Forum 1 April 24, 2016 14:35
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 18:44
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Flow field measurement in turbomachinery! Wanlai Lin Main CFD Forum 3 September 3, 1999 12:06
