February 18, 2022, 08:26 |
Meshing near edges
Raj Dasari
Rep Power: 4 |
Hello everyone
I'm new to Star ccm+ software. I was trying to do meshing for a simple geometry and the edges of the geometry in not meshed properly. I have attached the pictures of the meshing. Please suggest me to solve this problem. |
February 19, 2022, 09:35 |
Chaotic Water
Rep Power: 17 |
Please suggest how the edges of the geometry should be meshed properly.
February 21, 2022, 06:56 |
Raj Dasari
Rep Power: 4 |
It is a cylindrical geometry with two different diameters. After meshing the smaller Diameter circular edge is completely deformed.
February 21, 2022, 14:06 |
Hollis Williams
Rep Power: 4 |
I'm not an expert but that mesh looks quite coarse, what happens if you try a finer mesh?
Just clear meshes, change the parameters, then run everything again with a finer mesh. |
[Other] Meshing sharp edges | kandelabr | OpenFOAM Meshing & Mesh Conversion | 1 | August 25, 2017 09:02 |
[ANSYS Meshing] Smoothening ofSharp Edges for easy Meshing | Saksham Bhutani | ANSYS Meshing & Geometry | 2 | November 28, 2015 06:56 |
[ANSYS Meshing] How to not consider all edges during meshing | RodriguezFatz | ANSYS Meshing & Geometry | 19 | November 26, 2015 07:39 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Boundary layer meshing with sharp trailing edges | Andrew Berner | FLUENT | 1 | August 28, 2007 17:39 |
