How do you map the data from one simulation onto another for initialisation?
Old   November 16, 2019, 05:42
Default How do you map the data from one simulation onto another for initialisation?
Rikesh Mistry
rm24 is on a distinguished road
I have a simulation which has run under steady conditions. I want to change one of the region's continua to close a flowloop essentially.
I tried changing the continua and running he simulation on but get an error (floating point divided by 0). When I reset the mesh and clear solution and change continua of the region the simulation runs fine, so the issue appears to be when I change the continua on a simulation that has already run.
How do I map the simulation data from my first run into another with an identical mesh ie initialise a simulation with results from a previous mesh.
rm24 is offline   Reply With Quote
Old   November 16, 2019, 13:26
cwl
Chaotic Water
cwl is on a distinguished road
It should work ok when you switch from steady to unsteady.
Look for the mistake.
cwl is offline   Reply With Quote
Old   November 16, 2019, 13:55
Rikesh Mistry
The issue is not the switch to unsteady, this works fine.
The problem is when I change the continua of a previously fluid section to that of a solid (to close a valve )
Old   November 18, 2019, 04:35
cwl
Chaotic Water
That is too "sudden" change and incorrect in general.
If you want to close the valve - you can model valve by:
- using overset/rotating region;
- using porous media with resistance increasing over time;
- setting momentum source in a valve region to reduce velocity to zero.
initial condition, map fields, star ccm
UDF value to large for defined data type Anna73 Fluent UDF and Scheme Programming 9 September 30, 2018 22:18
Extracting data after simulation is done cyln OpenFOAM Running, Solving & CFD 1 May 22, 2018 15:36
Temporal and Spatial Varying Data for pre-simulation and actual simulation ssmeherk OpenFOAM Running, Solving & CFD 0 April 24, 2018 08:34
ABL simulation with experimental data: problems and doubts Davide_sd OpenFOAM Running, Solving & CFD 0 May 22, 2013 18:35
What if my simulation results are far from experiment data? yanxiaoxu CFX 2 April 11, 2013 09:16
