Difference between mesh created from Operations node and Continua node |
November 16, 2019, 04:57 |
Mandeep Shetty
Rep Power: 10 |
Hello, I am a newbie at using StarCCM+. I am trying to learn to mesh but I am confused with the meshing using the Operations node and the Continua node. What is the difference between these two different meshing options?
Ok from what I can understand the meshing from Operation node leads to Part based meshing and the one from Continua node leads to Region-based meshing. What is Part based continua nad how is it different from part based meshing? Last edited by granzer; November 16, 2019 at 10:40. |
November 16, 2019, 12:15 |
Lucky
Rep Power: 66 |
Continua is where you typically start.
Operations introduces pipelines and adds automation, allowing you to automate the meshing process for a general scenario so that you can run hundreds of cases. Not all features are available in operations. If you plan on only running a few cases, continua and working with regions is the most straightforward way to do so. |
November 18, 2019, 04:38 |
#3 | |
Chaotic Water
Rep Power: 17 |
- more than one Part can correspond to a Region; - part-based meshing meshes Parts, region-based meshing meshes Regions. |
meshing basics, star ccm+ |
