Thin Mesher with curvature
Like Tree1Likes
  • 1 Post By me3840
Old   December 28, 2019, 18:07
Default Thin Mesher with curvature
vedmak is on a distinguished road
Hello guys!
My goal is to simulate CHT through two adjoining solid walls. Compared to the fluid domain those walls are quite thin --> thin mesher
Now, in the final geometry there is curvature involved. I struggle a lot bacause of this, see attached pictures.
Without the curvature there is no problem at all. I`m using the latest StarCCM+ version.
All input appreciated
vedmak is offline   Reply With Quote
Old   January 1, 2020, 22:37
me3840 is on a distinguished road
You should really build a directed mesh for this, it will give you the best results.
If you wish you continue unstructured, the thin mesher can be finicky sometimes. Generally speaking I use a part control to manually specify the thin mesher settings, even if they're the same as the defaults (this forces the mesher to believe the part is thin).
There is also an advanced option to change a maximum face size ratio which may help. It does seem odd to me that it's not making the whole thing thin.
vedmak likes this.
me3840 is offline   Reply With Quote
Old   January 7, 2020, 11:49
Thumbs up
Ohhhh!
Didn`t think anyone would comment after a few days past...
Thank you A LOT me3840! This works out just perfectly!
Distance between walls with thin wall/shell conduction mir9283 FLUENT 0 May 16, 2018 04:49
[ANSYS Meshing] ANSYS Mesher cann't update geometry from parameter set M.Shousha ANSYS Meshing & Geometry 4 November 25, 2016 06:11
Issues with embedded thin mesher with poly and remeshing skiingengineer STAR-CCM+ 7 September 30, 2016 01:51
[ANSYS Meshing] Meshing thin surface in Ansys meshing Scotty ANSYS Meshing & Geometry 1 August 15, 2014 12:39
Modelling thin surfaces in 5.6 Louwrens CFX 0 August 16, 2003 11:47
