February 4, 2020, 02:43 |
Velocity inlet at a point.
Andrea
Hi all,
I am relatively new to Star CCM+, and I am currently working on simulating fluid flow around a circular cylinder for a project I have. I want to add a velocity inlet at two particular points (Point A and Point B) on the cylinder in order to suppress vortex shedding in the wake of the cylinder. So in total, I will have 3 velocity inlets. One which is part of the boundary wall upstream of the cylinder, and the remaining two at points A and B. Not sure if this is possible. Thanks. |
February 4, 2020, 08:59 |
Lucky
Rep Power: 66 |
A velocity inlet at a point is not possible. You need to think in terms of volumes and surfaces. A "point" does not exist in this landscape.
You can apply a momentum source at a single volume. You can apply a velocity inlet on a single face. But points don't exist. |
Pressure problems with inlet variable velocity | jaimesdiegop | CFX | 2 | September 1, 2016 02:31 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 10:34 |
Setting Density for Velocity Inlet Face | arkie87 | FLUENT | 0 | November 7, 2012 15:15 |
[swak4Foam] groovyBC, coupling inlet with velocity at specific point location | olivierG | OpenFOAM Community Contributions | 6 | June 23, 2012 08:44 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
