About Heat Flux Equation in StarCCM+ manual
Old   March 25, 2020, 16:37
Default About Heat Flux Equation in StarCCM+ manual
Jung Il Shu
jshu004 is on a distinguished road
Hello Star-CCM+ users,
I am doing a turbulent heat transfer simulation and going through a difficulty understanding the heat flux equation (eqn. 257) shown in User Manual.
In OpenFoam, the heat flux is calculated using:
q"=\frac{k_{eff}}{C_{p}}\frac{\partial(C_{p}T)}{\partial y}
evaluated at y=0.
Why these equations are different? I do understand the equation in OpenFOAM.
When I simulate a simple turbulent heat transfer using both StarCCM+ and OpenFOAM, the heat flux obtained from StarCCM+ is little different from OpenFOAM.
Anyone teach me about the heat flux equation used in StarCCM+?
My detail questions are:
1) why the ustar is used in equation?
2) does the parenthesis mean a function of a variable?
e.g.) \rho_f(y_{c}) is a density as a function of y_{c}?
3) what does the denominator mean?
Thank you in advance.
Best Wishes,
Jung Shu
jshu004 is offline   Reply With Quote
Old   March 26, 2020, 10:40
Matt
fluid23 is on a distinguished road
Are you working in an old version or something? I tried to pull up these help files and found a slightly different description that what you show. Long story short, it looks like the the open foam equation is in differential form while the star-ccm equation is worked out a little more fully.
Basically, all that non-sense in front of the (Ts-Tc) term is the local heat transfer coefficient, whereas (I suspect, but I don't know for sure) that keff in openfoam is a global value and that the actual deployment of the equation looks much closer to Star-CCM.
To answer your questions:
1) u* appears in the numerator to cancel out the u* inside the prandtl number (see no. 3) to give local heat transfer coefficient.
2) yes, density, specific heat capacity and non-dimensional temperature can (and are allowed to) vary with wall distance. These are describing functions of wall distance.
3) the denomentator is only T+ (dimensionless temperature = Prantdl No * y+ which is a function of u* and y). They are simply stating that T+ varies with wall distance.
fluid23 is offline   Reply With Quote
How is the Heat Flux calculated in CFD? CellZone Main CFD Forum 2 November 30, 2023 20:42
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 20:01
