Monitoring position of a point
Like Tree2Likes
  • 1 Post By Oculosdegrau
  • 1 Post By Sebastian3232
Old   October 2, 2020, 06:23
Default Monitoring position of a point
Oculosdegrau is on a distinguished road
Hello, new to CFD here
I modelling a plain bearing, whose journal has a bore. I would like to monitor the height of the gap above the bore and also the height of the lowest distance between journal and shell.
I have a coordinate system at the center of the journal and another at the center of the shell. When the journal and shell are concentric, these would be coincident. I figured I could place a point at the center of the bore outlet's face, and calculate it's distance to the shell center. Then, I could subtract the shell radius from this distance to find the gap height. The problem is, I dont know how to extract the position of a point.
For the second measument, I could simply subtract the position of the bores from one another. Could you guys show me how to extract this monitor, or if there is a better way to do it? Much appreciated!
SiemenDiemon likes this.
Oculosdegrau is offline   Reply With Quote
Old   October 4, 2020, 09:07
Sebastian Guaqueta
Sebastian3232 is on a distinguished road
Good day
You must be sure the point will move and not to get static, for this when create the point you must link it to the part/parts will move (in the parts ... selector), second you must activate "follow motion" option.
to create a monitor of the point's position, you must create an XY plot and select "Scalar" at the data type option and select for X and Y which scalar do you need, for point's position you look for position ion X,Y or Z direction axis. To select the body you need to track, in the "parts" option select the derived part "point" you created.
Hope this work for you
Sebastian3232 is offline   Reply With Quote
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 18:05
How to track position of centreOfMass or one point on object Nik_984 OpenFOAM Post-Processing 2 November 14, 2018 11:30
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 06:51
Creation of monitoring point itsme_kit FLUENT 1 December 5, 2013 14:33
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
