October 2, 2020, 06:23 |
Monitoring position of a point
Rep Power: 5 |
Hello, new to CFD here
I modelling a plain bearing, whose journal has a bore. I would like to monitor the height of the gap above the bore and also the height of the lowest distance between journal and shell. I have a coordinate system at the center of the journal and another at the center of the shell. When the journal and shell are concentric, these would be coincident. I figured I could place a point at the center of the bore outlet's face, and calculate it's distance to the shell center. Then, I could subtract the shell radius from this distance to find the gap height. The problem is, I dont know how to extract the position of a point. For the second measument, I could simply subtract the position of the bores from one another. Could you guys show me how to extract this monitor, or if there is a better way to do it? Much appreciated! |
October 4, 2020, 09:07 |
Sebastian Guaqueta
Rep Power: 6 |
Good day
You must be sure the point will move and not to get static, for this when create the point you must link it to the part/parts will move (in the parts ... selector), second you must activate "follow motion" option. to create a monitor of the point's position, you must create an XY plot and select "Scalar" at the data type option and select for X and Y which scalar do you need, for point's position you look for position ion X,Y or Z direction axis. To select the body you need to track, in the "parts" option select the derived part "point" you created. Hope this work for you |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
How to track position of centreOfMass or one point on object | Nik_984 | OpenFOAM Post-Processing | 2 | November 14, 2018 11:30 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
Creation of monitoring point | itsme_kit | FLUENT | 1 | December 5, 2013 14:33 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
