October 7, 2020, 09:40 |
STAR-CCM+ double to mixed precision
David
Does anyone know what happens to the accuracy of the field functions when a simulation that has been run in a double precision version of the code is later opened (for viewing the solution only) in the mixed precision version? I am running simulations in a cluster which has the double precision version, but I view the solution on my workstation which has the mixed precision version.
October 13, 2020, 09:03 |
Ping
Rep Power: 20 |
if you can see the difference between 7 digits of precision and 15 digits in your typical field function displays and plots then that would be quite amazing. dp is only important during solution for convergence reasons when using more advanced physics
#starccm+ |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
what's wrong about my code for 2d burgers equation | morxio | Main CFD Forum | 3 | April 27, 2007 10:38 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
