Pressure on Star-CCM+
Old   October 14, 2020, 13:16
Default Pressure on Star-CCM+
andrew spiteri
minox101 is on a distinguished road
Hello.
I am trying to simulate air underneath different head pressures. I have designed a box where I can vary pressure by changing the initial pressure. But I want to specify the pressure at the air velocity pressure as atmospheric pressure is there any way I can do this ?
minox101 is offline   Reply With Quote
Old   October 31, 2020, 18:46
Sebastian Engel
bluebase will become famous soon enough
Originally Posted by minox101 View Post
Hello.
Hi Andrew, could you rephrase your question please?
It's not explicit what you want to do. You have a box. Are there any inlets/outlets? If there are such boundaries, you have the options to make them stagnation inlet/outlets where you set the total pressure. The velocity magnitude "evolves" during the simulations.
Regarding atmospheric pressure, StarCCM has a constant offset for pressure (likely to reduce rounding errors). This constant is typically set to one atmosphere. So in the default case, 0 Pa (relative Pressure) actually means an absolute pressure of 1013 hPa.
If you would now set an inlet boundary to 1bar, it would actually be 2bar absolute pressure.
If you have a box without any flow inlets/outlets, then you might need to give more detail on your question, because i can't interpret it in this context.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 12:23
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
Marine Propeller Hydroacoustic Simulation in Star CCM BlackEagle STAR-CCM+ 1 December 8, 2017 21:33
error in star ccm maurizio Siemens 3 October 16, 2007 05:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
