Getting the coordinates of a local coordinate system |
October 16, 2020, 11:00 |
Rep Power: 5 |
I have a local coordinate system that is managed by a motion. Is there a way to get the position of this system at each step (in relation to laboratory) and plot it/export data/use data in a field function? Thank you |
October 17, 2020, 11:03 |
Chaotic Water
Rep Power: 17 |
The first thing that comes to mind - is to place a Point into origin of moving coordinate system, set that Point to follow the Motion and report its coordinates.
October 19, 2020, 04:56 |
Rep Power: 5 |
Hello cwl,
I thought about doing this too, but I couldn't figure out how to report the point position. I thought about using the Position field function, but I guess that is not what is meant for (rather to define a quantity over space). Do you know which field function gives me the coordinates of a point? Sorry for the rookie questions! |
October 23, 2020, 09:25 |
Matt
Rep Power: 17 |
Position is a vector quantity. $$Position[0] is X, $$Position[1] is Y, and I bet you can guess Z. I believe you can specify a user defined coordinate system by $$Position(@CoordinateSystem("user csys"))[0], etc...
Next, create a derived part > point and define it at [0,0,0] in your local coordinate system "user csys" then use that as an input for max or min reports of the position vector quantities [0], [1], [2]. That should do it, but I have not tried it myself. If that works for you, please report back. |
October 26, 2020, 04:42 |
Rep Power: 5 |
Hi Fluid23, thank you for your reply!
Unfortunately that did not work. I did as you said, but the report cannot generate a real result: Maximum of Position[Z] on Geometry Part Value (m) Errors ------ -------------- ------------------------------- Point -1.797693e+308 no data, invalid part ------ -------------- ------------------------------- Total: -1.797693e+308 no data, incomplete computation In my case I have a circular surface (jounal), so I guess I could simply do the surface average of Position[1], but thats pretty janky... |
October 26, 2020, 10:06 |
Matt
Rep Power: 17 |
Not sure, but this could be a problem with how you've set it up. I think I have seen this happen when the location is outside the computational domain. Some screenshots of the report setup and domain would be helpful.
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
In which coordinates system is expressed velocity | malaboss | OpenFOAM Post-Processing | 2 | April 18, 2013 06:00 |
local coordinate system for porousZone | Nico A. | OpenFOAM Programming & Development | 0 | November 15, 2011 04:32 |
