October 27, 2020, 06:03 |
Implementing FFT in Field Function
Madrigal
Rep Power: 5 |
Hello everybody,
I am new to this forum and a doctoral student. I am currently using Star CCM+ to simulate fluids flowing down a wire. This works very well. I use a field function on the inlet to set the speed of the fluid, which then flows down the wire. Using another field function, I now generate a forced disturbance (frequency) in the flow (sinus function). Using post-processing (FFT) I also find the frequency of the disturbance at the inlet. Now to my question: I have seen in different publications that also a white noise was simulated. For this I must add to my above mentioned field function for the velocity an another field function, instead of the forced interference frequency (see picture). For this I must add to my above mentioned field function for the velocity another, instead of the forced interference frequency (see attached Thumbnails). How should I implement the lower equation as a field function ? I would be super grateful if someone could help me . best regards CFD2DXY |
November 3, 2020, 09:28 |
Table/Fieldfunktion Problem
Madrigal
Rep Power: 5 |
Hello everybody,
I have now solved the problem with the help of a matlab code. I was able to generate random values with a function. Now I am confronted with the problem that I want to add a random value to my function for the velocity at the inlet (radial profile) at every time step. I have written the following field function: ${velocity u} + interpolateTable(@Table("file"), "column1", LINEAR, "column0",${TimeStep}) where column1: timestep from 0 to 8 seconds and column0: Random value, which should be added to the field function at each time step. I have started the simulation but still have a constant inlet-speed. Does anyone have an idea what my error could be? Greetings |
November 3, 2020, 11:30 |
#3 | |
Madrigal
Rep Power: 5 |
${velocity u} + interpolateTable(@Table("file"), "column1", LINEAR, "column0",${Time}) greetz |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
