NACA 0012 - Dynamic stall
Old   November 3, 2020, 08:29
Default NACA 0012 - Dynamic stall
Francisco Machado
Chary_w0w is on a distinguished road
Hi everyone,
I am currently studying dynamic stall for a NACA 0012. I want to have my airfoil pitch from 0 to a certain AoA and then decrease back to zero, with some frequency: alpha(t) = alpha + alpha_oscillation * sin (wt). This is the equation I want to obey.
I've read about overset meshes. Can I use it? And if so, how can I make it change to a certain angle, then to go back to zero, and all of this with the frequency (period) I want?
I hope I was clear and explained myself well. I really need your help.
Thank you!
Chary_w0w is offline   Reply With Quote
Old   December 9, 2021, 01:38
Moulishwar
Moulishwar is on a distinguished road
I know this is a quite a late reply, but I hope it'll be of use to someone who's looking for an answer to the question posted.
You can defined the motion that the overset mesh needs to follow by going through the following steps:
1. Goto Tools->Right click on Motions->Select Rotation
2. Now, Goto Regions->Your rotating body->Physical Values->Motion Specification->Rotation(under motion)
3. You can specify the rotation by making use of User defined field functions and assigning that function to the body.
Hope this helps!
Moulishwar is offline   Reply With Quote
Data for NACA 0012 Muntazir Main CFD Forum 1 March 28, 2023 01:59
Dynamic Stall of NACA 0012 Airfoiol AS_Aero CFX 0 April 4, 2019 08:30
problem with stall in naca 0012 airfoil thanos FLUENT 0 February 18, 2010 11:36
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 11:42
Looking for experiments in dynamic stall Anton Lyaskin Main CFD Forum 0 February 10, 2003 03:57
