post-processing of the particles
Old   November 17, 2020, 21:58
Default post-processing of the particles
mohammad
mohammad is on a distinguished road
Q: I know that there exists a particle demonstration (not a simulation of course) in SOLIDWORKS, where you can inject dummy particles to your steady-state simulation and see their movement along the streamlines. Is a similar option (trick) possible in STARCCM+?
I have simulated an axial fan. However, for better post-processing, I am intended to add some particles to move from the inlet of the domain towards the outlet. I remember one guy had done it some years ago, by adding kinda dummy particle after the simple single-phase simulation had been finished.
I do not remember what he did clearly. it was somehow injecting particles to the inlet and de-activating the solver parts, except the Lagrangian.
I did the same thing, the solution is ok...BUT IT TAKES TIME TO LET THE PARTICLES MOVE FROM THE INLET TO THE OUTLET OVER TIMESTEPS.
I AM LOOKING FOR A FAST METHOD.
Tnx,
mohammad is offline   Reply With Quote
Old   November 18, 2020, 08:25
Matt
fluid23 is on a distinguished road
To mohammad: What makes them dummy particles, exactly? It sounds a bit like you are describing a line integral convolution or some kind of streamline rather than 'injected particles'. There are lots of options for displaying vectors and streamlines, but having particles implies some kind of multi-phase model.
To profi_star-ccm+:
Can you clarify your rant, please? Why would this be advisable? Best practice usually does not result in the need for extreme fidelity for which you seem to advocate. How is using models that are built into the software to simplify certain types of analyses an attempt to deceive? I don't mean any disrespect, I just don't understand the point you are trying to make.
fluid23 is offline   Reply With Quote
particle, particle animation, post-processing
post processing for CEL expressions Niru CFX 0 May 10, 2013 13:13
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 06:21
Post: Particles Rate per Volume Rita CFX 0 January 5, 2007 12:59
fluent for post processing James FLUENT 0 April 21, 2006 04:43
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
