carpark "scalar issue"
Old   December 19, 2020, 03:42
Default carpark "scalar issue"
OK
Abdelrahman KHAMMASH is on a distinguished road
Hi everyone
-How much should I define the co source in the car burning in the carpark in kg/s
-How can I obtain this result (ppm) as scalar or graph as this picture
Note I used Eulerian mutliphase / VOF in the setup
Thank you very much
Abdelrahman KHAMMASH is offline   Reply With Quote
Old   December 19, 2020, 12:31
Sebastian Engel
bluebase will become famous soon enough
Do you really need multiphase (VOF) here? It seems rather expensive to me for this problem. Instead i would use a passive scalar if the CO concentration is so low. I might be naive here, but do the properties of the air composition change significantly in a carpark?
The graph shown is likely a plane section through the domain showing a field function which represents the concentration of that CO phase/scalar.
Initially the scene will likely show SI units. If you do not find a unit you are looking for in the possible alternative units, then you have to define one yourself with the respective conversion factors. Have a look into the manual, and than in the units object of the project tree.
A good idea to find an approximation of how much co is sourced into the domain is by finding similar research. There you'll usually find specific boundary conditions. Such information usually is a good start to extrapolate boundary conditions to a similar case.
Hit google scholar with "cfd carpark co concentration", there is at least one accessible publication considering your application.
Best Sebastian
bluebase is offline   Reply With Quote
Old   December 19, 2020, 16:20
OK
Thanks for reply sir
I tried to use passive scalar , I dont know really if I use it in the right way because I use it with Eulerian multiphase . is it right or should I use with another physical setup.
Note: I used Eulerian to apply the second material (co)
Thank you again
Old   December 20, 2020, 08:09
Sebastian Engel
Which similar studies did you find, and what methods did they use?
As i indicated before, air quality sims regarding co is not yet in my list of experience, so i can't definitely tell what is the right approach here, and just guessed... leading to my initial question why the fluid composition cannot be assumed to be perfectly mixed.
Old   December 20, 2020, 11:55
OK
I found someone do it using Autodesk cfd software
https://forums.autodesk.com/t5/cfd-f...k/td-p/8140235
my study idea is simple I need a car to produce a "CO" gas then I need it to interact with air in the carpark with jet fans , the jet fans and the other boundaries I defined them normally in separate study to see if they work properly and they did.
but when I wanted to add "CO" the results was not Satisfying.
please till me if I didn't answer your question
I can give any data you need to know don't hesitate to ask .
Old   December 21, 2020, 14:31
Sebastian Engel
What information do you find here https://scholar.google.com/scholar?q...+concentration ?
In case you are in a country without access to services like google, you might need to find an alternative platform to find research.
If you are in an university or alike, you might ask your supervisor for recommendations.
Last edited by bluebase; December 21, 2020 at 14:41. Reason: suggestion not suitable for restrictive countries
Speed difference of "scalar, label" with"double, int" sharonyue OpenFOAM Programming & Development 2 April 25, 2017 08:00
Carpark CFD analysis ali.soufan Main CFD Forum 0 November 21, 2015 12:53
Validation of carpark impulse/jet fans Henry Ho Phoenics 3 July 6, 2009 06:59
Carpark CO Emission Modelling Paul Phoenics 0 March 31, 2008 01:15
