Modelling a filter as porous media
Old   February 1, 2021, 05:28
Default Modelling a filter as porous media
koecher is on a distinguished road
Hello everyone,
i am trying to model a filter using porous media in STAR-CCM+.
I want two things to get done with the porous media:
1. pressure drop via the filter
2. flow-straightening, the flow above the filter is turbulent, the flow below the filter after crossing the filter has to be laminar.
Does anyone have recommendations how to model this?
I tried via porous Region first but had the Problem that no flow-straightening and no pressure drop occured; the flow looked Always the same regardless the values for porosity and tortuosity, it Always just looked like a "normal fluid Region".
I also tried with porous media model but star automatically changed my interfaces to baffle and i couldnt Change them back to internal, and due to baffle interfaces not working with porous media model i couldnt manage that way neither.
Did someone model a filter and is able to give me some recommendations on how to set up and what values and Settings have to be taken?
Thanks a lot in Advance!!!
koecher is offline   Reply With Quote
Old   February 1, 2021, 20:18
cwl
Chaotic Water
cwl is on a distinguished road
You can learn more about modeling porous media if you spend some time on reading the manual - pp 3819 «Examples of Setting Porous Resistance Properties» for example.
cwl is offline   Reply With Quote
filter, porous media, porous media model, porous region
Thermal non-equilibrium porous media model with conjugate heat transfer Hexahedron FLUENT 9 February 22, 2023 02:55
2Phase flow simulation in Porous Media Ansys Fluent Yaqub FLUENT 0 June 22, 2017 03:46
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
modelling porous media Mine FLUENT 3 May 19, 2014 14:35
Porous media modelling in ANsys dreamlifter747 ANSYS 0 September 13, 2013 10:29
