discretize lift force
Old   February 7, 2021, 13:03
Post discretize lift force
Azim
hosseiniazim is on a distinguished road
HI every body!
i have a planing boat moving forward in free surface.
how i can export dynamic lift force and static lift force for it from star ccm?
hosseiniazim is offline   Reply With Quote
Old   February 8, 2021, 18:14
ali_Ebrahimi
ali_ebrahimi is on a distinguished road
Originally Posted by hosseiniazim View Post
HI every body!
1. You can use the following method to calculate the dynamic lift force
Report > [6-DOF body Acceleration ... minimum] > Force
And then apply direction force to the created report properties.
2. What do you mean by Static lift force?
Lift Force = 0.5. (lift coefficient).(density).(Area).(Velocity)^2
In static mode, the speed is zero, so the lift will be zero (Buoyancy Force = Weight Force)
ali_ebrahimi is offline   Reply With Quote
#dynamic_lift, #lift, #static_lift
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 18:05
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 04:47
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 07:07
