Plotting a Monitered Data vs. Physical Time
Old   June 14, 2021, 07:10
Post Plotting a Monitered Data vs. Physical Time
SimulatorMaster's Avatar
Onur
SimulatorMaster is on a distinguished road
Hello all
Hope you are doing well.
I have conducted a simulation in order to observe turbulence behavior in a tunnel. I have several points to capture velocity data and Monitor field functions to observe parameters such as variance covariance, Field Mean for velocity, Strain Tensors and such.
Now the problem is that I have forgot to implement a point in the region in which I also had to obtain velocity data.
Now I have several Field Means under Monitor section in which I can pull data from without needing to again capture the data for the missing point by re-running the simulation. But I cannot plot all the samples vs physical time which is not available as a scalar function so I tried iterations; however, it only displays the latest solved value(so the Sim. ended at 400k iterations and it shows the result at 400k).
Is there anyway to solve this problem?
Thank you for your time.
Sincerely
Onur
SimulatorMaster is offline   Reply With Quote
Old   June 15, 2021, 12:04
Nikolaos Papafilippou
Nikpap is on a distinguished road
I think star does not keep all the previous values in transient simulations.
What I do is that I make a table with the quantities I want and automatically export it every x amount of timesteps.
However this would mean that you'll have to rerun your simulations
Nikpap is offline   Reply With Quote
Old   June 16, 2021, 11:19
Onur
Yes unfortunately it seems that I need to rerun the simulation. Though thanks for the reply!
plotting
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 41 August 23, 2023 02:48
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 22:29
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
