November 30, 2021, 12:29 |
Problem with wave
Luca
Rep Power: 6 |
Hi all,
I'm trying to simulate a Wave with the following properties: Heigth= 6m Wavelength: 46m Period: 5s The Boundary condition are Velocity inlet at bottom, inlet, lateral and Top. Pressure out at the outlet. All the boundaries are set with the information of the Fifth order wave. The mesh is setting Isotropic with a dimension of 0.3m so that I have 20 cells for the height and 150 cells for the wavelength. The timestep is set in order to have CFL<0.5. The problem is that when I plot the Isosurface of the wave, I have the "non-continuity" of the wave on the boundary. It seems like the wave doesn't slip on the boundary. I attach the screen of the simulation to show the problem. Anyone can help me? Thanks! |
November 30, 2021, 16:03 |
#2 | |
Peresvet
Rep Power: 5 |
https://youtu.be/e8SWa9MwRJc |
December 1, 2021, 03:39 |
#3 | |
Luca
Rep Power: 6 |
December 1, 2021, 03:52 |
#4 | |
Peresvet
Rep Power: 5 |
You can use free surface adaptation by setting free surface volumetric control = 100% and adaptation = 3 or 4 maximum grind level. |
December 1, 2021, 03:56 |
Luca
Rep Power: 6 |
December 1, 2021, 04:19 |
#6 | |
Peresvet
Rep Power: 5 |
It might come in handy. |
December 1, 2021, 04:41 |
#7 | |
Luca
Rep Power: 6 |
About the adaptive mesh on the free surface, does it double the mesh size level by level? So I have to set the mesh under the last level in order to have the size of the mesh of 0.3m to the free surface?! Or Starccm+ calculate the best size based on my wave? I'm asking because I never used it! Thanks |
December 1, 2021, 05:52 |
#8 | |
Peresvet
Rep Power: 5 |
With the ratio = <17, the waves will decay along the length of the domain after a short time. Try building on automatic grids. https://youtu.be/MtjdC5NL2u0 |
December 1, 2021, 09:23 |
#9 |
Luca
Rep Power: 6 |
I set the adaptation. I can set only Volumetric or surface control, what do you mean with "setting free surface volumetric control = 100%"?
December 1, 2021, 09:41 |
#10 | |
Peresvet
Rep Power: 5 |
https://youtu.be/2doeE93APO0 --- free surface adaptation https://youtu.be/H3RXxEL1sG0 --- multi-step mode. |
December 2, 2021, 01:21 |
#11 | |
Peresvet
Rep Power: 5 |
It is a mistake in cfd to use a movable grid. The resistance in the boundary layer is calculated with high precision by other methods. Error in cfd less than 0.5%? !!! ?? !!! Moreover, all calculations are based on the usual fitting to a practical result. Units on planet Earth are able to count accurately enough without preliminary calculations. For example me. Sorry for being modest. |
problem with modeling tidal wave | saeed.13 | FLOW-3D | 3 | August 25, 2016 02:24 |
Help! Compiled UDF problem 4 Wave tank tutorial | Shane | FLUENT | 1 | September 3, 2010 02:32 |
Problem with a leapfrog scheme for wave equation | Shiranui | Main CFD Forum | 0 | June 22, 2010 09:19 |
how i can approch the problem about shock wave | chandrakanth | Main CFD Forum | 0 | December 6, 2008 02:27 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
