December 17, 2021, 17:42 |
CCM+: Simulations with a variable time-step.
Francesco Mariani
Rep Power: 14 |
Thank you very much to those who will and will be able to answer this question of mine.
Is it possible to run simulations with variable time-step? In particular, I'd like to change it all the time the CFL value changes. A similar way as Converge code operates. FrancescoM. |
December 18, 2021, 14:44 |
Lucky
Rep Power: 66 |
You can write your expressions and code.
You can also click the check box that says adaptive time step model. |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
