Error in volume meshing
Old   April 24, 2022, 14:52
Default Error in volume meshing
jfn
jfn's Avatar
jfn is on a distinguished road
I am importing an air vehicle with a surface mesh prepared before with any other mesher program. In Star-CCM+, I re-meshed the surface with surface remesher. When I try to generate the volume mesh with polyhedral mesher(without prism layer), it gives me the error: "can't recover edge near position:...". So I go to surface repair to see if there is anything wrong about the geometry but everything was fine. Then, I create probe at those points and notice that they are all on a thin edge. Then I re-meshed surface without CAD projection and those surfaces are now meshed with a fine progression without creating larger area ratios before and after of those thin edges. But is still gives me the same errors on the same locations.
Is there someone got the same error before?
Thanks
jfn is offline   Reply With Quote
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 03:23
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 04:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
