July 2, 2022, 02:54 |
Floating point error in PEMFC Simulation
Bharath
I am trying to replicate a fuel cell model which is simulated in ANSYS Fluent but I am constantly getting floating point error. I used the tutorial model as my base reference and build the set-up. errors like: "A non-finite residual (H2O) was added by star.segregatedspecies.SegregatedSpeciesSolver. and causing overflow, underflow or divided by Zero" I have attached Parameters and error occurred can you help me solve this problem thank you |
July 11, 2023, 23:51 |
Ontario
I have the same issue, that would be great if somebody assist :
in general, I am fixing this problem with these steps: 1-Your mesh is set to CFD, fluent and NOT mechanical 2- Your mesh should have at least a good skewness and orthogonal array value 3- you have unstructured mesh, with tringles arrangement 4-your mesh should show all the bodies of your geometry without cuts 5-If it did not initialize properly, reset the setting and do it again 6- for transient application, take PISO as your method 7- your timesteps must be less than 0.005 Finally, the real setup that really can solve this problem in the dynamic mesh is to activate Implicit Update Settings Unfortunately, it was not helpful here for me but you can try it as well! |
ERORR floating point exception fluent udf | cudau.95 | Fluent UDF and Scheme Programming | 0 | August 4, 2021 22:11 |
[blockMesh] Floating Point Exception while generating wedge based mesh | jns-v | OpenFOAM Meshing & Mesh Conversion | 9 | July 8, 2021 05:36 |
Error: Floating Point Exception. How do I fix this? | Ryan T | FLUENT | 16 | July 30, 2020 18:52 |
Floating point exception (yes...) | sandri_92 | OpenFOAM Running, Solving & CFD | 0 | October 23, 2016 14:42 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 19:28 |
