How to monitor surface temperature at different locations?
Old   April 16, 2012, 23:17
Default How to monitor surface temperature at different locations?
Jimmy
Jimmy123 is on a distinguished road
Hello!
I'm studying the heat transfer from air to a solid. I would like to compare (willingly by comparing plots) the results from the simulations with results from real experiments where I have measured the surface temperature at different locations. I was thinking that I could use probe points and drag them to the correct locations while using "snap to part", but then I saw that they don't snap to the boundary as I first thought with "snap to part" ticked.
So, how should I do instead? Divide the surface boundary into several small boundaries and take the surface average at those boundaries?
Jimmy123 is offline   Reply With Quote
Old   April 17, 2012, 01:42
Hamza Motiwala
hamzamotiwala is on a distinguished road
Hey Jimmy,
I think you should select the respective region/part in the "Input parts".(this is for probe points)
then click on "snap to part" and then turn it off again. This way the selection box snaps to the selected region or part containing the desired surfaces. Now you can just drag the point on the surface wherever you want.
and if you have the coordinates from your test rig then it will be much easier else you can approximate it according to your judgement.
I think this helps.
Cheers,
Hamza
hamzamotiwala is offline   Reply With Quote
Old   April 17, 2012, 05:52
Jimmy
Thank you for answering, but I had tried that already. Unfortunately, the parts are bending, so I get allot of space outside the part where I can accidently put the point.
Anyway, I got a superb tip from a friend that I would like to share. If I push the"." button, the output prompts the position of the mouse if I have it in a scene. So now I can easily write the position of my point probes manually. Problem solved!
Old   April 18, 2012, 05:50
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
If you measured in a line, then you can define a line probe first.
Then in the monitor, create a plot (xy-plot), change the axes to Scalar , use the line probe as one axis and a function as another axis.
Good luck
siara817 is offline   Reply With Quote
Old   April 24, 2012, 16:48
Jimmy
Thank you for the tip, I will have that in my mind next time!
Old   March 21, 2023, 05:20
Post Temperature in different surface
kirishanth
kirishanth is on a distinguished road
I am doing project in STAR CCM+ about Chaotic natural convection, and I am struggling to get temperature in surface,
Please kindly advise how do I get temperature in different surfaces
Thank You
kirishanth is offline   Reply With Quote
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 06:08
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
