Moving reference frame not rotating flow around propeller |
April 5, 2023, 04:17 |
Sabri
Rep Power: 3 |
Hello fellow CFD peeps,
I studying a propeller blade using the rotating reference frame approach. I have a small rotating domain with my propeller blade in a larger fluid domain. I included images of the domain. I interfaced the two regions with an internal interface and used periodic interfaces to create periodicity. After having run the simulations, I looked at my velocity vector profiles and it seems like my flow is not rotating at all. I included images of the vector plane normal to the rotation (YZ) and a cross-section of the blade. It seems the flow is both unperturbed and flowing right flow my blade. I am completely confused about what could have caused this issue and I am open to any advice for it. Domain.png Domainnear.png vectoryz.jpg bladecrosssectionvectors.jpg |
April 5, 2023, 19:26 |
Lefteris
Rep Power: 15 |
Did you plot them on the stationary or the rotating frame of reference?
Lefteris |
April 8, 2023, 07:32 |
#3 | |
Sabri
Rep Power: 3 |
I am not sure what you mean by did I plot them in the stationary or rotating reference frame? Do you mean the velocities? |
April 8, 2023, 09:53 |
#4 | |
Lefteris
Rep Power: 15 |
If memory serves you can plot the velocity vectors using either the lab coordinate system or the rotating. I'm not 100% though.
Lefteris |
April 10, 2023, 06:13 |
#5 | |
Sabri
Rep Power: 3 |
I was wondering if by any chance you also know if the thrust output of a periodic domain is that of the single blade or the hypothetical entire propeller? Now that I am certain my propeller rotates I noticed I am getting over 1kN of thrust per blade and that is impossible for a blade that is specified for 300N (or any normal blade tbh) 0.0 |
April 10, 2023, 07:11 |
Lefteris
Rep Power: 15 |
Oh I'm not sure to be honest.
The reason I'm not sure is that I think that Siemens has added some reports which can give you the value for the whole thing. Again, that's not something I've used and I might even be making this up but I think I read that in some newsletter. Check the help for the report you used.
Lefteris |
April 10, 2023, 07:13 |
#7 | |
Sabri
Rep Power: 3 |
April 10, 2023, 07:18 |
Lefteris
Rep Power: 15 |
No problem! Sorry I couldn't be more precise.
Have fun!
Lefteris |
April 10, 2023, 08:39 |
#9 | |
Sabri
Rep Power: 3 |
I think I will run an unsteady rigid body simulation and see if I get similar answers, because I cannot fathom how I could have messed up my simulation. Thanks again |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
how to treat the rotating zone in multiple reference frame (MRF) | Jiuan | FLUENT | 4 | May 24, 2010 21:58 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
