Type 1 vs Type 2 Polar like in XFLR5
Old   May 14, 2023, 11:21
Default Type 1 vs Type 2 Polar like in XFLR5
Kailee
Kailee71 is on a distinguished road
Hi all,
I'm just getting into Star-CCM+ and as a training exercise I'm going to do some 2D comparisons of airfoils for model aircraft. I have some experience in using XFLR5 to so similar comparisons and found the Type 2 polars that it produces very intuitive and helpful. In other places these polars are called dynamic polars. In a nutshell, it will adjust flow velocity such that for a particular airfoil and chord length, it produces plots of Cl/Cd for a particular Re*sqrt(Cl), which essentially means that for lower Cl values you're using higher free stream velocities. It's trivial generating Cl/Cd vs Cl plots using the design manager, but this would generate plots at constant Re, which is not what usually happens in real, equilibrated flight (you'll have lower Re at higher Cl unless you're pulling up at elevated speeds for instance).
I've tried to do this in Star-CCM+ but am failing; I thought to make reference velocity and cell initiation velocity dependent on Cl, but Cl only comes out of the sim itself... Ideally the input would be an actual value of Re*sqrt(Cl), which would then generate a flow velocity for that particular design (AoA & v), which would then be the basis for the mentioned plot.
Would anybody have any pointers as to how a plot like this could be generated in Star-CCM+?
Best of thanks in advance for any pointers,
Kai.
Kailee71 is offline   Reply With Quote
Old   May 15, 2023, 16:29
f-w
f-w's Avatar
f-w is on a distinguished road
To do this semi-auto, pick and fix AOA, then iterate using a macro on velocity until the calculated report value of Re*sqrt(Cl) hits your target, within tolerance. End result is a single data point for your plot. Within reason, start at a low AOA, and repeat in desired # of increments until you reach high AOA (or until you can't sufficiently converge); each of these is a data point.
For iterating on velocity, adapt the macro provided in the following knowledge base article:
https://support.sw.siemens.com/knowl...00031937_EN_US
You can use Design Manager to automate the whole process; it will iterate through AOA, the macro will iterate on velocity, while all you have to do is specify/pass through Re*sqrt(Cl) to the macro.
Cheers
f-w is offline   Reply With Quote
Old   May 15, 2023, 20:22
Kailee
Hi f-w,
yes I thought it would get to something like this. It'll be a good learning experience with design manager, I've only done some trivial AoA sweeps, so it's a step ahead!
Best of thanks for the pointer!
Kai.
Multiphase euler foam problem with velocity vector enthusiast OpenFOAM Running, Solving & CFD 1 January 20, 2023 03:54
About the totalPressure BC shock77 OpenFOAM Running, Solving & CFD 66 October 28, 2022 11:24
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
