NREL 5MW Wind Turbine Calculation 8MW power when pitch angle is changed.
Like Tree1Likes
  • 1 Post By fluid23
Old   May 11, 2023, 03:53
Default NREL 5MW Wind Turbine Calculation 8MW power when pitch angle is changed.
ParkJuyeol
park79950 is on a distinguished road
Hello, nice to meet you.
I am a student studying Star-CCM+ at a university in Korea.
doing power calculations for NREL 5MW models.
At 11.4 m/s, the rated wind speed of the NREL 5MW turbine, approximately 5MW power could be seen.
However, after rotating the blade pitch angle, the wind speed was changed, resulting in greater power (8MW).
I referred to the table of fig.1 (Table 7-1).
Fixed / 12.1 rpm
velocity / 15m/s
Was there a problem with my setup?
park79950 is offline   Reply With Quote
Old   May 12, 2023, 05:07
Lefteris
Aeronautics El. K. is on a distinguished road
I don't understand what the question is but I wonder, what are you simulating, what do you want to get out of the sim?
25m/s is Beaufort 10, do wind turbines operate at Beaufort 10 (storm conditions)?
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   May 12, 2023, 08:44
Matt
fluid23 is on a distinguished road
I think I understand the question and a windspeed of 25 m/s is not impossible, but at the upper limit of practicality. The NREL 5MW turbine to which I assume we are referring has a cutout windspeed of 25 m/s so it would start breaking and not generate power at or above that speed. However, just before cutout you would expect to see more power than the 'rated' condition of 5MW if you aren't relying on a pitch controller to limit the torque supplied to the generator and keep you in the 5MW range.
Basically, a 5MW rating and a 5MW limit are not the same thing. Just because it's called a 5MW turbine doesn't mean it can't do 5.1 MW or 6MW or 8MW on paper... I emphasize that last part.
https://www.nrel.gov/docs/fy09osti/38060.pdf
Aeronautics El. K. likes this.
fluid23 is offline   Reply With Quote
Old   May 15, 2023, 15:13
Lefteris
Thanks for the insight Matt!
Lefteris
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
Torque calculation of 2D VAWT Wind Turbine Anonymized_JL1 FLUENT 14 September 26, 2013 03:35
Compute the power of small wind turbine. Luolin FLUENT 9 May 27, 2013 14:52
about wind turbine power prediction with cfd windman FLUENT 1 January 11, 2007 06:41
