Virtual disk: Advance ratio report
Old   May 17, 2023, 08:03
Default Virtual disk: Advance ratio report
ale
a.gmira is on a distinguished road
Good afternoon,
I am running selfpropulsion simulations for a ship with virtual disk model and Body Force Propeller method. As the operation point input option I am selecting Thrust. Also, I am running in model scale and adding a Skin Friction Correction Force as a force CM (DFBI).
The values I get for Thrust deduction fraction and Wake fraction (with Thrust Identity method)are reasonable. However, the advance ratio (J) report from the simulation is lower than the one I calculate as J=V/(n*D), where V is the velocity of the farflow. The one I get in the simulation is 0.50 and the calculated one by me is 0.58.
Does anyone know if I should get J=0.58 from this type of report? or how that report calculates the advance ratio?
Thank you in advance!
Kind regards,
A.gmira
a.gmira is offline   Reply With Quote
Old   May 17, 2023, 09:44
Matt
fluid23 is on a distinguished road
The report pulls velocity from the inflow plane so I would assume that your inflow velocity and far-field velocity are not the same.
fluid23 is offline   Reply With Quote
Old   May 19, 2023, 07:33
ale
Do you know exactly which velocity in the inflow plane is it using to calculate the advance ratio? Because I am taking the average of the axial velocity, velocity (i), etc., to calculate it but they dont give me the same value as the report.
Old   May 19, 2023, 07:55
Matt
According to the help files:
"The velocity components and the density of the fluid approaching the virtual disk are volume-averaged over the inflow velocity plane. The averaged velocity components are then projected onto the normal plane of the virtual disk to yield one average velocity vector value."
[FSI] Having trouble installing FSI_4.0 on foam-extend 4.1 and Ubuntu 16.04 Aliiiii OpenFOAM CC Toolkits for Fluid-Structure Interaction 11 May 26, 2022 05:00
Virtual Disk Model-Report afarkas STAR-CCM+ 2 July 7, 2017 05:29
Install/compile fireFoam 1.6-1.0 in Openfoam 2.1.1 hz283 OpenFOAM Programming & Development 19 April 1, 2013 08:35
Propeller thrust at diff. advance ratio (CFX 5.7) Zoltan CFX 9 April 27, 2005 08:23
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
