Lagrangian Multiphase model
Old   October 2, 2012, 22:20
Unhappy Lagrangian Multiphase model
niuprats is on a distinguished road
Hello All
Does anyone here has an experience working in Lagrangian Multiphase model in STAR CCM+ 7.04.011??
If yes please can you reply to the post ASAP.
Thank you for your time and help in Advance.
niuprats is offline   Reply With Quote
Old   October 3, 2012, 02:51
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Can you explain that what is the problem.
siara817 is offline   Reply With Quote
Old   October 3, 2012, 13:30
Hey Saira817
Thanks for getting back.
I'm actually trying to model lagrangian multiphase model with mesh morphing.
Im working on bridge pier scouring ,two-phase sediment transport,using lagragian model along with mesh morphing.Here,im trying to entrain the sand particle from the bed using erosion rate field function as well as move the bed using some grid velocity.
But while running this i get this error in the attached file.
Regards
Old   October 4, 2012, 03:40
siara817's Avatar
Do you mean that you have used erosion model to cause erosion of sediment? what is the particle phase in the water?
Old   October 4, 2012, 03:52
Yes exactly,erosion model in Lagrangian phase which is solid particle with 0.00025 m of diameter and 2650 density.
Old   October 5, 2012, 04:14
siara817's Avatar
Actually, I do not know what is wrong in this case. But, in erosion, erosion happens on a surface by some particles. What is surface material and what is particle material?
Old   October 8, 2012, 16:57
Well ,my bed surface is a sand sediment,and particles are sand.
I defined the bed surface as wall, in order to calculate the wall shear stress.
Old   June 4, 2015, 07:13
Ayush Jain
Ayush Jain is on a distinguished road
Hi niuprats,
I have a doubt that erosion is actually a long time process, so if you want to model
changing the geometry using morphing, how will you decide your physical time and time step.
Ayush Jain is offline   Reply With Quote
Old   September 26, 2023, 08:06
Turbo_jet_Noida
bin_naqkse_kadam is on a distinguished road
Can we set lagrangian phase to be initially present in cfd domain?
bin_naqkse_kadam is offline   Reply With Quote
Multiphase model in Fuel Cell module E-Font FLUENT 0 March 9, 2011 14:44
Multiphase and Radiation Model in Fluent LucioBP FLUENT 0 January 30, 2011 14:41
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
multiphase model & separation naser FLUENT 5 June 9, 2006 06:12
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
