October 3, 2023, 02:18 |
variation in simulation results
Shubham Chauhan
Rep Power: 2 |
Hello everyone,
I'm a motor design engineer currently engaged in thermal simulations for a motor using Star CCM. I've successfully created a 3D model of the motor and proceeded to analyse the temperature distribution within the windings. The meshing of the model has also been completed. The corresponding losses for each component are as follows @6769rpm: Winding: 338.66 W (density : 8933, specific heat 385, thermal conductivity 401) Stator: 77.62 W Rotor: 7.57 W Magnets: 2 W Bearing-1: 12 W Bearing-2: 3 W In the simulation, all walls have been defined as adiabatic. As per the setup, the motor winding is expected to reach a temperature of 120°C after 30 minutes (starting at 40°C). However, based on the simulation results, the winding temperature is reaching 42°C after 30 minutes. It's important to note that in order to get desired results in my analysis, I've been using a multiplication factor of 20 (which is varying for different cases) to calculate losses and account for various conditions. I'm seeking assistance to identify any potential discrepancies or oversights in my simulation setup. Any insights or guidance would be highly appreciated. Thank you. image 7 is without using factor and image 8 is multiplying the losses by 21 |
#motor, #starccm+, #thermal |
Start the unsteady computation based on the steady simulation results | Amber0922 | SU2 | 2 | July 22, 2023 22:23 |
Imprecise results in SU2 Simulation of a Turbulent Susbonic Round Jet | LucaLamberti | SU2 | 1 | May 24, 2020 23:47 |
Ahmed body simulation gives unexpected results in su2 6.0 | anas651 | SU2 | 0 | March 28, 2018 03:42 |
No variation in the temperature contour in the results | madan | CFX | 7 | February 3, 2015 10:32 |
Same model and settings, but different simulation results? | N263883A82261 | Main CFD Forum | 1 | May 24, 2014 12:29 |
