Axi-symmetric modeling?
Old   May 3, 2009, 11:59
Default Axi-symmetric modeling?
Digital_Junkie
MaxCFM is on a distinguished road
I have a 3D model (nozzle) that I'd like to convert into an axi-symmetric model. What is the simplest way to do this? The help files have not been much help. I've tried converting the 3D mesh into 2D but when I try to change the X-axis boundary type to an axis boundary there is no axis type in the drop-down box. There is no geometry located in -Y. Model type is axi-symmetric in physics continuum. If I select symmetry it treats it as 2D.
Apparently I can't remesh a 2D model either. That makes it a real pain. Is this correct?
Thank you
MaxCFM is offline   Reply With Quote
Old   June 1, 2009, 05:22
Bernard Esterhuyse
bernarde is on a distinguished road
Hi
I have been looking at this type of problem as well. As far as I understand you are not able to model an axisymmetric model as purly a 2D model. A pure 2D model in Star-CCM+ does not allow you to specify any property out of the plane (such as a tangential velocity for swirl in a pipe).
To achieve an axysimmetric model you have to model a wedge, and then make use of periodic boundaries. The angle of the wedge must be such to ensure a good aspect ratio of the cells on the axis, ie you cannot have a wedge that is too sharp. The periodic boundaries must also be indentical in shape.
I found this restriction quite frustrating. I would have liked to be able to construct a 2D model, and then specify an axis, and be able to specify properties perpendiculat to then plane, that are axisymmetric about this axis. I suspect this is what you are also aiming for?
Regards
bernarde is offline   Reply With Quote
Old   June 1, 2009, 09:24
Digital_Junkie
Yes, that is what I desire. In my limited experience this is one area where Fluent beats Star-CCM+ hands down.
Axi symmetric flow Emmanuel Resch Siemens 4 February 10, 2008 13:29
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 19:08
