May 30, 2010, 21:55 |
strain rate magnitude
ahmad bakri
Rep Power: 15 |
hi all
I have a problem, if I want to use the strain rate function inside the star ccm+ I have two options: 1.$StrainRate which can be used as field function 2. Strain Rate Magnitude which shows the values of strain rate in some section i tried to run some simulation of a process, when I compared both functions they had the same values but, the first one didnt have the same distribution a long the cross section plane (i.e. the plane had only one value which is the smallest one, but the bar gave the same values as the bar in the Strain Rate Magnitude) does any body know how to use the 2nd functoin because it is the true one in terms of strain rate values and distribution not like the 1st one which has only the same values but with wrong distribution, or how can I make them identical thanks |
June 3, 2010, 13:03 |
Aroon
Rep Power: 17 |
Seems the first one is the vector function while the second one is the magnitude.
strain rate in UDF | Paulina | FLUENT | 11 | November 20, 2014 03:06 |
UDF for critical strain rate to extinction | Birute Bunkute | FLUENT | 1 | March 25, 2010 15:40 |
About "Shear strain rate" | leo1985 | CFX | 0 | April 26, 2008 04:48 |
Strain rate. | MM? | Main CFD Forum | 1 | February 15, 2006 08:55 |
strain rate at arbitrary position in a cell | K. Kevala | FLUENT | 0 | February 4, 2004 17:14 |
