Turbulence Model L.E.S
Old   June 21, 2009, 06:13
Default Turbulence Model L.E.S
Hamoudi djamel
hamoudi is on a distinguished road
Good Moning Everybody,
Please if every one can answer me, i am doing a simulation in 2D
Can i use L.E.S as a turbulence Model in 2D simulation
because L.E.S turbulence model is very robust
Thank you in advance
hamoudi is offline   Reply With Quote
Old   June 22, 2009, 07:31
Maddin is on a distinguished road
You can but sure that you want this?!
Maddin is offline   Reply With Quote
Old   June 23, 2009, 10:53
Aroon
vishyaroon is on a distinguished road
If you talk to people who work with LES, they will frown if you call it a model, because LES resolves the turbulent scales.
I'd say 3D is better. 2D suppresses the vortices and/or turbulence fluctuations in the third direction (that you are not considering) thereby resulting in some underpredictions. I'd not say that 2D is not feasible, but I'd stay away from 2D if I'm doing LES. In fact even 2D cases are sometime handled as 3/2D where you have periodicity in the thrid dimension.
vishyaroon is offline   Reply With Quote
Old   July 16, 2009, 08:45
matej forman
matejfor is on a distinguished road
LES is not a robust turbulence model K-eps is robust model. LES resolves turbulence scales and models only the very small ones. If you run 2D LES your results will be rubbish, as the turbulence is not averaged and you must preserve the 3D nature of it. For LES you need much finer grid and small time step and you should know what you're doing. If you want results looking like LES but with cheaper calculation you should try SAS turbulence model (but I do not think it is availible in CCM, you have to go ANSYS to get it).
matej
matejfor is offline   Reply With Quote
Old   July 16, 2009, 08:52
In CCM you only have DES when you run unsteady. Steady you don't have this, AFAIK.
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 02:29
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
validating turbulence model on flow around a car Pedro CFX 1 February 20, 2008 16:32
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
