Intake manifold analysis
Like Tree1Likes
  • 1 Post By Vinicius
Old   July 4, 2010, 01:41
Default Intake manifold analysis
alonzoo is on a distinguished road
Hi,everyone,I have encountered a problem while running an analysis for an intake manifold in star ccm.the error message I received was as follows:
Sever error:a floating point has occurred:floating point exception.
And in the residuals window, all the residuals show solution divergence during the first iterations.
Below is my model information:
Geometry dimension:unit mm
Inletiameter:27àoutlet:ares:380,length:70 àsection of pipe: ares:820 ,length:105;
mesh models:
surfaces remesheràpolyhedral mesheràprism layer mesher
reference values:
base size:5 àprism layer thickness:2.5àrelative minimum size(surface size) :1à relative target size(surface size) :2àothers:default
physical models:
3DàstationaryàsteadyàIdeal gasàsegregated flowàstandard k-Epsilon tuberlenceàhigh y plus wall treatment, click on incompressible in the ideal gas property window.
Reference values:deault
Initial conditions:
Pressure:750pa(half of the pressure difference between inlet and outlet) àturbulence length scale:2 mmàturbulent intensity:0.04àothers:default
Boundary conditions:
Inlet:stagnation . total pressure:1500pa.Outletressure out pressure:0pa.
other parameters keep as initial conditions.
alonzoo is offline   Reply With Quote
Old   July 4, 2010, 14:32
Vinicius Girardi
Vinicius is on a distinguished road
Try to run some iterations using a velocity or mass flow rate at the inlet. It's better if you know one of these values. Then just go back to your pressure-pressure condition.
y_c_w likes this.
Vinicius is offline   Reply With Quote
Old   July 6, 2010, 04:00
Maddin is on a distinguished road
Ramp the pressure...
Maddin is offline   Reply With Quote
intake manifold simulation uday Main CFD Forum 6 December 21, 2009 01:39
need help with manifold analysis in fluent anil1886 FLUENT 0 August 29, 2009 10:29
Intake manifold analysis mehndan Siemens 3 August 22, 2008 04:24
Intake manifold analysis mehndan Main CFD Forum 6 July 3, 2008 05:28
Modeling of a airflow in a intake manifold Jack FLUENT 1 September 21, 2003 22:22
