August 15, 2010, 22:02 |
Difficulty meshing a two region problem
James C
Rep Power: 15 |
I am have difficulty properly meshing a simple case containing a solid rectangular cooling channel with fluid flow through the center (heat transfer will occur from the outside of the cooling channel and into the working fluid). For some reason the surface mesh along the boundaries and symmetry plane are not creating a closed set of mesh surfaces - the result is that there are not only gaps with no nodes, but I cannot generate a volume mesh. I followed the meshing tutorials and the information did not help me in this case. The only thing that seems to help is increasing the number of points in gap (this improved things but nothing more). I also tried decreasing the mesh size in each of the specific regions on the non-global level. I have some experience with Star-CCM+, but only with single region fluid flow (no heat transfer). I am trying to learn more about the software and how to create multiple regions and incorporate heat transfer. I have attached screen shots which help to illustrate my problem. Any help you can provide me with would be great - Thank you. James |
August 16, 2010, 05:58 |
Rep Power: 15 |
hi,
welcome in my world i had the same problem you have a typical non-conformal mesh. did you try use only one mesh continuum? |
August 16, 2010, 09:29 |
sven
Rep Power: 15 |
Maybe one of the following hints might help.
- inspect your import mesh prior defining Interfaces. (Surface Repair Tool, NonManifold Edges checked). Boundary between solid and fluid should have blue edges on all perimeters. If not repair the geometry. - redo your model with only one side of fluid solid interfaces. After importing the geometry, use the "convert to interface" option to fully create the interfaces necessary. - define feature curves (boundary perimeter) prior surface meshing. - enable / disable the "project to cad" feature these are rather guesses, so no guarantee that they will improve anything |
August 17, 2010, 00:50 |
Hello james
by creating features curve u can avoid this problem to create features curve see help in star ccm+ |
August 18, 2010, 10:24 |
James C
Rep Power: 15 |
I have tried a few of the things mentioned with no luck:
-Disabling project to CAD did help seal up the outer region (not the ends), that is once i deleted the fluid region. -I also tried having one interface, but that did not help either. -I also am using one mesh continum What i will try next is to play around with feature curves and see where that takes me. Thanks for the help so far. James |
August 19, 2010, 01:10 |
hi james try this too
reduce the mesh size by decreasing the base size in mesh
heat transfer, meshing, symmetryplane, two region |
Suggestions for a multi region conjugate heat transfer problem | maddalena | OpenFOAM | 14 | September 4, 2013 18:03 |
[Other] Shadow wall region problem | amoolraina | ANSYS Meshing & Geometry | 0 | July 25, 2010 21:17 |
Gambit meshing problem | David Banks | Main CFD Forum | 0 | July 19, 2007 11:48 |
problem in meshing a periodic boundary | dumas | FLUENT | 4 | March 8, 2006 10:54 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
