February 27, 2012, 04:14 |
Porous Medium
sam
This is sam from coimbatore,India.I've read the below content.I have a doubt in this, how could i calculate the Dp/L by using CFD sofware. Let i take pipe Dia 250mm length 2m. The porous region is located at 1m(middle section) porous thickness 0.25m.In this i have to consider either Total pipe length 2m or Porous lg 0.25m for find initial Parameter of Dp/L with diff velocity V m/sec for get the excel plot(K and C2). Anyone can help me Regard, Sam ******************************* The formula is Dp/L= [(viscosity/alpha)*velocity]+ [C2*1/2*density*velocity^2] (dp/l =viscousr resistance + inertial resistance) plot dp/l vs velocity in excel. The pressure drop can be obtained from cfd. The values for velocity can be arbitrarily chosen say for ex. 0 to 20 m/s (even more if you want more points) Plot Dp/L vs velocity based on above formula and examine the curve how it looks like. If it is a straight line then use only dp/l=viscous resistance. If it is a quadratic equation use (dp/l =viscousr resistance + inertial resistance). Find K and C2 with these curves. Hope this helps . cheers Nelly |
March 7, 2012, 18:07 |
Rep Power: 21 |
You only have to consider the porous part of your domain, since the straight pipe before and after the porous part is not covered by the Dp/L formula.
It depends on your type of problem whether you can take Dp/l from a CFD simulation or not. Please describe your problem a little more accurately. What parameters do you have? What do you want to know? How does your porous part look like? |
March 9, 2012, 04:36 |
#3 | |
sam
Actually i want to simulate the Pr.drop by CCM+ software itself. u r saying i've consider where the porous region is present for find Dp value am i right(need not consider the total pipe length)? u consider above pipe dimension,at middle the cotton matl is present...what will be pr drop effect by cotton matl? and how to do this in CCM+? give me ur idea ..... Adv Thanx Regards, Sam0508 |
Flow through porous medium using CFX: lack of convergence | Chander | CFX | 3 | July 23, 2014 06:32 |
Lack of local thermal equilibrium in porous medium | Chander | CFX | 4 | March 4, 2012 04:07 |
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? | Chander | CFX | 3 | November 28, 2011 14:26 |
Modelling sound propagation through layered porous media | nkinar | Main CFD Forum | 0 | July 4, 2010 14:45 |
porous medium and reactions | Valeria | FLUENT | 1 | July 10, 2009 03:58 |
