March 16, 2015, 22:34 |
No steep rise in pressure curve
Balaji
I am currently simulating HCCI Mode of Combustion with n - heptane as the fuel. My problem is that I am unable to get a steep rise in the pressure curve although I have a considerable amount of heat release (perceived from the spd file) I have given the following parameters as the input
1. combustion model - ECFM-3Z 2. Cetane no - 60 3. Eq ratio - 0.29 4. EGR - 0% 5. Initial Pressure - 6.14 bar 6. Initial Temp - 503K 7. Injected Mass - 4.716e-4 kg/s (pls tell me whether this mass is sufficient for combustion or not) Should I need to change any of the ignition parameters? |
March 19, 2015, 02:42 |
#2 | |
Can
Firstly, what is your injector hole diameter? You should write its diameter values as meter (m) in Pro-Star. And I guess eq ratio should be bigger, for example 0.85. I usually use Lambda value for air/fuel mixture.(Lambda = 1.5-1.8 for diesel engines). I am not sure about the mass of injected fuel. Maybe you should check it by using 1D simulation. Quote:
March 19, 2015, 03:05 |
Balaji
Thanks for the reply. My injector hole diameter is 0.188mm. I have found out that my injection mass was not sufficient for combustion. Can you please help me in deciding the ignition model ? |
March 19, 2015, 03:44 |
Can
InterPhaseChangeFoam ERROR | shipman | OpenFOAM Running, Solving & CFD | 37 | March 23, 2014 12:43 |
pressure coefficient on hip roof low rise building | maaz | FLUENT | 0 | February 10, 2014 02:50 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
rotating domain - pressure rise | petp | CFX | 2 | April 5, 2008 07:03 |
