Home > Forums > General Forums > Structural Mechanics
Restart (continue) converged solution from endpoint
Old   August 23, 2017, 11:23
Default Restart (continue) converged solution from endpoint
ISV
ISV is on a distinguished road
Hey!
So this is basically my problem:
I'm modelling steel cables. I fixate one end and impose an axial displacement in one of them. The settings are defined in order to get to a 8% of deformation in 10 secs.
My problem is that I want to get one of the models to go beyond this 8%, so I wanted to add a new setp to go from the time t=10 to t=11. It seems that I had the Retain Files After Full Solution option in "No" so after the model converged in the 10 sec I have no restart points available.
Is there a way to create a restart point at the time t=10 so I can go from there and add a new setp?
Cheers.
ISV is offline   Reply With Quote
Old   August 31, 2017, 16:25
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Well if you didn't save the restart pts in mechanical (rescont option). You can still do singleframe restart procedure (ref to Ansys Mechanical APDL feature - chapter 3). This is only possible if you have the .db, .emat (if created) and .esav otherwise you’ll need to restart from scratch.
If you have those files you can add a snippet under the solution branch, resume the db file, enter the solver “branch” with /solve then specify that it’s a restart -> Antype,,Rest
Have fun
Gweher is offline   Reply With Quote
Strange results in converged solution Pastukhov CFX 5 January 16, 2017 00:52
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 0 June 22, 2016 08:26
Total Heat imbalance even if solution 'converged' AmitKunte FLUENT 1 March 30, 2016 16:39
Continue the solution from where the license is timed out ashtonJ CFX 3 March 12, 2012 19:13
solution converged shaswat CFX 7 February 6, 2012 18:48
