November 15, 2017, 10:36 |
Simple supported beam, incorrect solution
DamianB
Hello!
I'm new to ANSYS and don't quite get along with this software. I'm trying to do a simple analysis of beam shown below. I specified beam section with MM: Processor -> Sections -> Beam -> Common Sections and applied R=0.02257(which corresponds to A=0.0016), N=12, T=8. I keep getting this incorrect solution where beam is bending the opposite way than it's supposed to. Here's my code: Code:
ENTER /SHOW,DEVICE-NAME TO ENABLE GRAPHIC DISPLAY ENTER FINISH TO LEAVE PREP7 PRINTOUT KEY SET TO /GOPR (USE /NOPR TO SUPPRESS) ELEMENT TYPE 1 IS BEAM188 3-D 2-NODE BEAM KEYOPT( 1- 6)= 0 0 0 0 0 0 KEYOPT( 7-12)= 0 0 0 0 0 0 KEYOPT(13-18)= 0 0 0 0 0 0 CURRENT NODAL DOF SET IS UX UY UZ ROTX ROTY ROTZ THREE-DIMENSIONAL MODEL *** PROPERTY TEMPERATURE TABLE NUM. TEMPS= 1 *** SLOC= 1 0.000000 PRINTOUT RESUMED BY /GOP PROPERTY TABLE EX MAT= 1 NUM. POINTS= 1 SLOC= 1 0.2100000E+12 PROPERTY TABLE PRXY MAT= 1 NUM. POINTS= 1 SLOC= 1 0.3000000 ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= Assignment5_try4.db FOR POSSIBLE RESUME FROM THIS POINT PRODUCE NODAL PLOT IN DSYS= 0 INPUT SECTION ID NUMBER 1 INPUT SECTION TYPE BEAM INPUT BEAM SECTION SUBTYPE Circular Solid INPUT BEAM SECTION NAME BEAM SECTION WITH SECTION ID NUMBER 1 IS OFFSET TO CENTROID SECTION ID NUMBER IS: 1 BEAM SECTION TYPE IS: Circular Solid BEAM SECTION NAME IS: COMPUTED BEAM SECTION DATA SUMMARY: Area = 0.16001E-02 Iyy = 0.20372E-06 Iyz = 0.97194E-23 Izz = 0.20372E-06 Warping Constant = 0.37199E-42 Torsion Constant = 0.40744E-06 Centroid Y = 0.41357E-18 Centroid Z =-0.15964E-17 Shear Center Y = 0.85597E-18 Shear Center Z = 0.33295E-18 Shear Correction-yy = 0.85698 Shear Correction-yz = 0.81254E-14 Shear Correction-zz = 0.85698 Beam Section is offset to CENTROID of cross section KEYPOINT 1 X,Y,Z= 0.00000 0.00000 0.00000 IN CSYS= 0 PLOT KEY POINTS FROM 1 TO 1 BY 1 KEYPOINT 2 X,Y,Z= 10.0000 0.00000 0.00000 IN CSYS= 0 PLOT KEY POINTS FROM 1 TO 2 BY 1 KEYPOINT 3 X,Y,Z= 20.0000 0.00000 0.00000 IN CSYS= 0 PLOT KEY POINTS FROM 1 TO 3 BY 1 LINE CONNECTS KEYPOINTS 1 2 LINE NO.= 1 KP1= 1 TAN1= -1.0000 0.0000 0.0000 KP2= 2 TAN2= 1.0000 0.0000 0.0000 LINE CONNECTS KEYPOINTS 2 3 LINE NO.= 2 KP1= 2 TAN1= -1.0000 0.0000 0.0000 KP2= 3 TAN2= 1.0000 0.0000 0.0000 PLOT KEY POINTS FROM 1 TO 3 BY 1 SET DIVISIONS ON ALL PICKED LINES TO NDIV = 10, SPACING RATIO = 1.000 NDIV AND SPACE CAN BE OVERRIDDEN FOR CURVATURE OR PROXIMITY PLOT KEY POINTS FROM 1 TO 3 BY 1 GENERATE NODES AND ELEMENTS ON ALL PICKED LINES NUMBER OF LINES MESHED = 2 MAXIMUM NODE NUMBER = 21 MAXIMUM ELEMENT NUMBER = 20 PRODUCE ELEMENT PLOT IN DSYS = 0 PRODUCE ELEMENT PLOT IN DSYS = 0 ***** ROUTINE COMPLETED ***** CP = 42.859 ***** ANSYS SOLUTION ROUTINE ***** PERFORM A STATIC ANALYSIS THIS WILL BE A NEW ANALYSIS KP NUMBERING KEY = 0 LINE NUMBERING KEY = 0 AREA NUMBERING KEY = 0 VOLU NUMBERING KEY = 0 NODE NUMBERING KEY = 1 TABN NUMBERING KEY = 0 SVAL NUMBERING KEY = 0 DOMA NUMBERING KEY = 0 NUMBER KEY SET TO 0 -1=NONE 0=BOTH 1=COLOR 2=NUMBER ELEM NUMBERING KEY = 0 KP NUMBERING KEY = 1 LINE NUMBERING KEY = 0 AREA NUMBERING KEY = 0 VOLU NUMBERING KEY = 0 NODE NUMBERING KEY = 1 TABN NUMBERING KEY = 0 SVAL NUMBERING KEY = 0 DOMA NUMBERING KEY = 0 NUMBER KEY SET TO 0 -1=NONE 0=BOTH 1=COLOR 2=NUMBER ELEM NUMBERING KEY = 0 KP NUMBERING KEY = 1 LINE NUMBERING KEY = 0 AREA NUMBERING KEY = 0 VOLU NUMBERING KEY = 0 NODE NUMBERING KEY = 1 TABN NUMBERING KEY = 0 SVAL NUMBERING KEY = 0 DOMA NUMBERING KEY = 0 NUMBER KEY SET TO 0 -1=NONE 0=BOTH 1=COLOR 2=NUMBER ELEM NUMBERING KEY = 1 KP NUMBERING KEY = 1 LINE NUMBERING KEY = 0 AREA NUMBERING KEY = 0 VOLU NUMBERING KEY = 0 NODE NUMBERING KEY = 1 TABN NUMBERING KEY = 0 SVAL NUMBERING KEY = 0 DOMA NUMBERING KEY = 0 NUMBER KEY SET TO 0 -1=NONE 0=BOTH 1=COLOR 2=NUMBER ELEM NUMBERING KEY = 0 DISTANCE MULTIPLIER FOR WINDOW 1 0.7290 DISTANCE FOR WINDOW 1 6.016 PRODUCE ELEMENT PLOT IN DSYS = 0 DISTANCE MULTIPLIER FOR WINDOW 1 1.372 DISTANCE FOR WINDOW 1 8.252 PRODUCE ELEMENT PLOT IN DSYS = 0 SPECIFIED CONSTRAINT UX FOR PICKED NODES REAL= 0.00000000 IMAG= 0.00000000 ADDITIONAL DOFS= UY ALL BOUNDARY CONDITION DISPLAY KEYS SET TO 1 SPECIFIED CONSTRAINT UX FOR PICKED NODES REAL= 0.00000000 IMAG= 0.00000000 ADDITIONAL DOFS= UY UZ ROTX ROTY ROTZ SPECIFIED SURFACE LOAD PRES FOR ALL PICKED BEAM ELEMENTS LKEY = 2 VALI,VALJ = -4000.0 -4000.0 PRES LOAD SURFACE DISPLAY KEY = 1 POINT LOAD ON ALL PICKED KEYPOINTS LOAD LABEL = FY VALUES = -15000. 0.0000 Code:
PRINT U NODAL SOLUTION PER NODE ***** POST1 NODAL DEGREE OF FREEDOM LISTING ***** LOAD STEP= 0 SUBSTEP= 1 TIME= 1.0000 LOAD CASE= 0 THE FOLLOWING DEGREE OF FREEDOM RESULTS ARE IN THE GLOBAL COORDINATE SYSTEM NODE UX UY UZ USUM 1 0.0000 29.352 0.0000 29.352 2 0.0000 0.0000 0.0000 0.0000 3 0.0000 28.247 0.0000 28.247 4 0.0000 26.860 0.0000 26.860 5 0.0000 24.980 0.0000 24.980 6 0.0000 22.492 0.0000 22.492 7 0.0000 19.370 0.0000 19.370 8 0.0000 15.686 0.0000 15.686 9 0.0000 11.603 0.0000 11.603 10 0.0000 7.3786 0.0000 7.3786 11 0.0000 3.3628 0.0000 3.3628 12 0.0000 0.0000 0.0000 0.0000 13 0.0000 -2.3608 0.0000 2.3608 14 0.0000 -3.7286 0.0000 3.7286 15 0.0000 -4.2790 0.0000 4.2790 16 0.0000 -4.1876 0.0000 4.1876 17 0.0000 -3.6302 0.0000 3.6302 18 0.0000 -2.7823 0.0000 2.7823 19 0.0000 -1.8197 0.0000 1.8197 20 0.0000 -0.91800 0.0000 0.91800 21 0.0000 -0.25288 0.0000 0.25288 MAXIMUM ABSOLUTE VALUES NODE 0 1 0 1 VALUE 0.0000 29.352 0.0000 29.352 Can someone please tell me what I'm doing wrong? Thank You in advance! |
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 08:20 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
