November 9, 2020, 12:01 |
Non-linear contact
Rakesh T
Rep Power: 5 |
I am analysing a pulley and shaft having its both ends fixed. A moment given to pulley and there is a friction between pulley and shaft. I was trying to evaluate mode shapes first with zero moment but ansys is giving popup nonlinear contact detected. Pulley and shaft are perfect fit. How do I make ansys understand that the moment applied for pulley gets transferred to shaft due to friction between them when performing transient analysis? Regards, Rakesh |
November 10, 2020, 03:44 |
Rep Power: 11 |
Use Bonded Contact.
November 11, 2020, 03:28 |
Rakesh T
Rep Power: 5 |
But the scenario should be like sliding at interface
Optimal tolerance and variables scaling settings | 4513645ygq | Main CFD Forum | 0 | July 28, 2020 08:56 |
2nd Order Convergence Problem for 3D Airfoil | turkmengokce | OpenFOAM Running, Solving & CFD | 1 | September 10, 2015 07:20 |
A turbulent test case for rhoCentralFoam | immortality | OpenFOAM Running, Solving & CFD | 13 | April 20, 2014 06:32 |
how to modify fvScheme to converge? | immortality | OpenFOAM Running, Solving & CFD | 15 | January 16, 2013 13:06 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
