October 3, 2021, 17:47 |
Solidworks splined shaft stress analysis
mahdi
Rep Power: 6 |
I'm not sure if this is the right thread; if its nor please point me in the right direction.
So I have to do a stress analysis on a drive shaft, using solidworks. But I'm not sure on how to actually model it. For example the motor is travelling at 2500 rpm with a torque output of about 2590Nm which then goes into a reduction gear box 1 5:1, so how do I go about modelling the torque output on the prop shaft? So essentially at the end if the shaft is a propeller and the shaft should be rotating at 200tpm with at torque of about 100NM. So the figures aren't correct; I just would like a general idea of where to go and what to do. |
October 5, 2021, 10:32 |
Rep Power: 11 |
Reductor reduce RPM and increase Torque.
Torque*RPM (in rad/sec) = Power. If we neglect power losses in reductor then RPM1*Torque1=RPM2*Torque2 Here 1 is values befora reductor and 2 denotes values after redsuctor. So you have 2500 rpm and 2590Nm before reductor and reductor ratio of 15:1 then you have 2500/15=167 RPM and 2950*15= 44250 Nm torque after reductor. https://courses.lumenlearning.com/su...tional-motion/ |
Thermal stress analysis with heat flux boundary condition | cvasse | OpenFOAM Running, Solving & CFD | 0 | March 20, 2018 09:46 |
Need help with transient flow analysis of intake manifold using SolidWorks. | IronWeber | CFD Freelancers | 1 | October 21, 2016 10:27 |
thermal stress analysis? | Jinfeng | Main CFD Forum | 1 | January 21, 2009 08:26 |
stress analysis | rt | Main CFD Forum | 0 | June 7, 2007 05:01 |
force for stress analysis | yunk | FLUENT | 0 | February 15, 2006 07:18 |
