November 18, 2021, 18:11 |
Abaqus is unable to locate a C++ compiler
Hello everyone,
i need to use uMat and user subroutines in Abaqus for my masters thesis. I installed Abaqus 2020, Visual Studio 2019, Intel oneApi Base Toolkit and Intel oneApi HPC Toolkit (in this exact order). After successfully linking the Fortran Compiler (Intel Fortran Compiler 2021.4) with VS19 (setting all the path variables and editing the abaqus2020.bat and the abaqus_v6.env) i started Abaqus Command (as admin) and used the command: abaqus verify -user .. it PASSED right away. My main problem is the following: If i plug in "abaqus info=system" everything is fine except the C++ Compiler. C++ Compiler: Unalbe to locate or determine the version of a C++ compiler on this system. If a C++ compiler is installed on this system, please load vcvars64.bat file before running Abaqus I tried every possible solution i could imagine: - different versions of VS - different OS - different Processor - calling the vcvars64.bat in abaqus2020.bat - Installing third party c++ compilers (MinGW) I just can't find a solution to this issue. I hope someone here can help me with this problem. My current setup (if that helps): Processor: AMD Ryzen 5 3600 RAM: 32 GB DDR4 3200 Graphics: MSI NVidea Geforce GTX 1660 Ti OS: Windows 11 Linker Version: Microsoft Incremental Linker Version 14.29.30137.0 Fortran Compiler: Intel Fortran Compiler 2021.4 MPI MS-MPI 9.0.12497.11 (This is my first post in this forum - please don't be too hard on me) I am grateful for any help - Thank you |
May 16, 2024, 07:20 |
Have you solved the problem yet?
I got exactly the same issues and don't know what to do anymore... |
[OpenFOAM.com] Installing on Ubuntu 18.04 | samiam1000 | OpenFOAM Installation | 11 | April 27, 2020 00:01 |
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 2 | April 20, 2020 13:50 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
