Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 compilation with MPI option
Old   February 11, 2013, 10:00
Default SU2 compilation with MPI option
Vincent RIVOLA
vinz is on a distinguished road
Dear all,
I downloaded SU2 and managed to compile it in serial mode without problem.
On my system I also have OpenFOAM installed.
When I try to install SU2 with MPI option, I get de following error:
I use the following configuration:
./configure --with-MPI=mpic++ --with-Tecio=/usr/software/tecplot/lib --with-CGNS-lib=/usr/local/lib --with-CGNS-include=/usr/local/include
then running make gives me:
Making all in trunk/Common/lib
make[1]: entrant dans le répertoire « /home/vincent/SU2v2.0/trunk/Common/lib »
if mpic++ -DPACKAGE_NAME=\"SU\^2\" -DPACKAGE_TARNAME=\"SU\^2\" -DPACKAGE_VERSION=\"2.0\" -DPACKAGE_STRING=\"SU\^2\ 2.0\" -DPACKAGE_BUGREPORT=\"susquared-dev@lists.stanford.edu\" -DPACKAGE=\"SU\^2\" -DVERSION=\"2.0\"  -I. -I.    -I/usr/local/include -DNO_METIS  -g -O2 -MT ../src/libSU2_a-config_structure.o -MD -MP -MF "../src/.deps/libSU2_a-config_structure.Tpo" -c -o ../src/libSU2_a-config_structure.o `test -f '../src/config_structure.cpp' || echo './'`../src/config_structure.cpp; \
    then mv -f "../src/.deps/libSU2_a-config_structure.Tpo" "../src/.deps/libSU2_a-config_structure.Po"; else rm -f "../src/.deps/libSU2_a-config_structure.Tpo"; exit 1; fi
../src/config_structure.cpp: In constructor ‘CConfig::CConfig(char*, short unsigned int, short unsigned int, short unsigned int, short unsigned int)’:
../src/config_structure.cpp:36:9: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp: In member function ‘void CConfig::SetPostprocessing(short unsigned int, short unsigned int)’:
../src/config_structure.cpp:1978:11: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp:1990:11: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp: In member function ‘void CConfig::SetMarkers(short unsigned int, short unsigned int)’:
../src/config_structure.cpp:2054:13: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp: In member function ‘void CConfig::SetFileNameDomain(short unsigned int)’:
../src/config_structure.cpp:3871:6: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp:3877:6: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp:3882:6: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp: In member function ‘void CConfig::UpdateCFL(long unsigned int)’:
../src/config_structure.cpp:3965:12: erreur: ‘MPI’ has not been declared
../src/config_structure.cpp: In member function ‘void CConfig::SetNondimensionalization(short unsigned int, short unsigned int)’:
../src/config_structure.cpp:4500:9: erreur: ‘MPI’ has not been declared
make[1]: *** [../src/libSU2_a-config_structure.o] Erreur 1
make[1]: quittant le répertoire « /home/vincent/SU2v2.0/trunk/Common/lib »
make: *** [all-recursive] Erreur 1
The mpi installed is the one comming with the last version of openfoam:
 ~/SU2v2.0 > mpic++ -v
Utilisation des specs internes.
COLLECT_GCC=/usr/bin/g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
Target: x86_64-linux-gnu
Configuré avec: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.3-1ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Modèle de thread: posix
gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5)
What is going wrong?
vinz is offline   Reply With Quote
Old   February 20, 2013, 02:12
Thomas D. Economon
economon is on a distinguished road
Hi Vincent,
Do you also have Metis version 4.0.3 on your machine? If not, could you please install this version and add it to your configure options above (i.e. --with-Metis-lib & --with-Metis-include options)? Metis 4.0.3 can be found here: http://glaros.dtc.umn.edu/gkhome/fsroot/sw/metis/OLD.
Metis will need to be linked in at compile time and SU2_DDC will need to be used to partition the mesh before SU2_CFD is called. This process is all automated by using the parallel_computation.py script.
Hope this helps!
Tom
economon is offline   Reply With Quote
Old   February 20, 2013, 08:26
Vincent RIVOLA
Hi Tom,
Thanks for your reply.
However, it still does not work.
Here is my configure command:
./configure --with-MPI=mpic++ --with-Tecio=/usr/software/tecplot/lib --with-Metis-lib=/home/vincent/SU2v2.0/trunk/metis-4.0.3 --with-Metis-include=/home/vincent/SU2v2.0/trunk/metis-4.0.3/Lib
the configuration is ok:
Build Configuration Summary:
          Source code location:     /home/vincent/SU2v2.0
          Install location:     /usr/local
          Version:                  2.0
          Compiler:                 mpic++
          Preprocessor flags:
          Compiler flags:           -g -O2
          Linker flags:
          CGNS support:             no
    MPI support:             yes
    Metis support:        yes
    Build SU2_CFD:         yes
    Build SU2_DDC:         yes
    Build SU2_GPC:         yes
    Build SU2_MAC:         yes
    Build SU2_MDC:         yes
    Build SU2_PBC:         yes
    Build SU2_SMC:         yes
but then the compilation still crashes:
if mpic++ -DPACKAGE_NAME=\"SU\^2\" -DPACKAGE_TARNAME=\"SU\^2\" -DPACKAGE_VERSION=\"2.0\" -DPACKAGE_STRING=\"SU\^2\ 2.0\" -DPACKAGE_BUGREPORT=\"susquared-dev@lists.stanford.edu\" -DPACKAGE=\"SU\^2\" -DVERSION=\"2.0\"  -I. -I.    -DNO_CGNS -I/home/vincent/SU2v2.0/trunk/metis-4.0.3/Lib   -g -O2 -MT ../src/libSU2_a-config_structure.o -MD -MP -MF "../src/.deps/libSU2_a-config_structure.Tpo" -c -o ../src/libSU2_a-config_structure.o `test -f '../src/config_structure.cpp' || echo './'`../src/config_structure.cpp; \
Old   February 20, 2013, 16:26
Thomas D. Economon
You may want to get a fresh copy of MPI and configure/build it yourself (I am not sure how your mpic++ is configured). For instance, I have had success compiling for parallel runs on my laptop using Open MPI with the GNU compilers. You can find Open MPI here: http://www.open-mpi.org. Let me know if this works...
Old   March 5, 2013, 10:05
RDG
onyir is on a distinguished road
Hi Vincent,
did you finally get SU2 to compile?
I'm experiencing the same problem as you did and I'm not able to make it work.
Regards,
Ricardo.
onyir is offline   Reply With Quote
Old   March 7, 2013, 03:02
Vincent RIVOLA
Unfortunately no, I did not have much time to work on this and since I managed to compile the code on our cluster, it was fine for me.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
