Home > Forums > Software User Forums > SU2 > SU2 Installation
how to locate mpi.h using ./configure
Old   September 16, 2014, 16:47
Default how to locate mpi.h using ./configure
Sean (J.X.) Shi
momo_sjx is on a distinguished road
I am working on a server.
I found mpicxx and mpi.h are not in standard library.
When I use /configure --prefix=/home/user/SU2 --with-MPI=/usr/mpi/bin/mpicxx
then make, it returns
../src/../include/config_structure.hpp:27:17: error: mpi.h: No such file or directory
The mpi.h is located in /usr/mpi/include.
How to solve this problem?
Thank you in advance.
momo_sjx is offline   Reply With Quote
Old   September 22, 2014, 08:18
Khiem Pham
Bachduong is on a distinguished road
Perhap, you may find folder, which contain mpicxx. In my case it locate in usr/bin.
Good luck
Bachduong is offline   Reply With Quote
Old   September 22, 2014, 09:47
Jeffrey van Oostrom
Doriris is on a distinguished road
I have had the same issue on my machine, which had MPI pre-installed. I suggest you simply rebuild OpenMPI or any other on your machine/server, such that the MPI.H file is in the correct folder.
Jeffrey
Doriris is offline   Reply With Quote
How to locate all the edge node by UDF? hadesmajesty Fluent UDF and Scheme Programming 1 August 7, 2013 03:52
Tutorial 8 - Unable to locate import executable Kambusha CFX 0 April 10, 2009 07:58
a cone injection,please help me!! satum FLUENT 0 July 2, 2008 02:38
How to locate the place of injector ? haixiao Siemens 2 April 6, 2006 20:55
CCM+: unable to locate Java VM Amod Kumar Siemens 0 March 22, 2005 00:42
