February 21, 2018, 06:53 |
SU2 transition modeling
mike
Dear All;
I am a new user of SU2 code. I'm going to implement Gamma-Retheta SST transition model in SU2 code. Has anybody done similar development? Where should I start from? Any help is appreciated. |
February 24, 2018, 13:46 |
Francisco Palacios
Hi Mike,
Welcome aboard! Implementing a transition model it will take some time. My recommendation is to get familiar with the software (e.g. the SA turbulence model) and start from that. There is a transitional method in SU2 https://su2code.github.io/tutorials/...al_Flat_Plate/ you can take a look at the tutorial Best, Francisco if you are interested in developing SU2 maybe SU2 IDS www.su2devsociety.org is interesting for you. Best, Francisco |
March 4, 2018, 23:10 |
mike
Thanks Francisco.
I have run those available transition case studies. I am going to study pitching airfoil, too. The available cfg files for unsteady cases are transonic flows at Ma=0.7. My problem is incompressible. Since I am a new user, I don't k7now which commands must be change in available transonic cfg pitching foil. Would you please help me with an incompressible cfg pitching file? Regards |
B-C transition model in SU2 | whizkid | SU2 | 2 | November 27, 2017 02:03 |
SU2 LM Transition Model (v4.1.0 cardinal release) | whizkid | SU2 | 1 | January 26, 2016 04:46 |
su2 transition point and output settings | varghese9 | SU2 | 2 | March 5, 2015 12:13 |
Transition modeling using K-w | Athar | CFX | 1 | November 25, 1999 01:40 |
Transition Modeling using CFX4.2 | Athar | Main CFD Forum | 1 | November 24, 1999 15:02 |
