Home > Forums > Software User Forums > SU2 > SU2 Installation
Parallel computation on windows 8
Old   February 21, 2020, 13:20
Question Parallel computation on windows 8
serg
kont87 is on a distinguished road
I googled it but could not find the answer. My problem is, when I use "parallel_computation.py" script, all cores run the whole mesh instead of a partitioned one, and each core performs each iteration (4 cores = 4 identical solution), but if I use mpiexec -n #cores SU2_CFD.exe [config file] instead, It works. I have no problem with that, but for the optimization tutorials, I could not solve the issue and running the optimization cases on a single core is pretty annoying.
I followed the steps -which is very straightforward- for a Win machine, I did not compile the code by using cygwin. I have the latest version of SU2, python version is 3.8.1, numpy's is 1.18.1, scipy's is 1.4.1
I have MS-MPI, version is 10.1.12498.18. SU2_RUN, path for MPI and python are set accordingly.
Any help is appreciated.
Regards.
S.
kont87 is offline   Reply With Quote
Old   February 22, 2020, 12:22
pcg
Pedro Gomes
pcg is on a distinguished road
Do you have more than one mpi version in your system?
The optimization script might be calling mpirun instead (not sure what is the default).
If you run mpirun -n # SU2_CFD do you get the same problem?
pcg is offline   Reply With Quote
Old   February 22, 2020, 13:58
serg
It seems mpirun is not recognized in my system whereas mpiexec is, do you have a suggestion?
Thank you.
Old   February 26, 2020, 06:18
pcg
Pedro Gomes
You can define a custom mpi command via environment variable SU2_MPI_COMMAND, this is used in $SU2_RUN/SU2/run/interface.py, if all else fails you can always hack that script.
Old   February 27, 2020, 11:19
serg
Problem is solved, thank you for your help. I have now another issue, which is exactly as described in here:
https://github.com/su2code/SU2/issues/559
I am just going over the tutorials, and not changing anything in the config files, yet I can't detect the problem. Do you have any idea?
The problem when i use parallel computation for mesh deforming. Hiroaki Sumikawa OpenFOAM Running, Solving & CFD 0 November 20, 2018 02:58
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
Windows 7 parallel calculations curky SU2 Installation 23 May 14, 2013 02:17
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 10:26
about parallel computation akang CFX 5 June 22, 2005 10:51
