Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2-7.0.1 on ubuntu 18.04
Old   February 28, 2020, 01:24
Default SU2-7.0.1 on ubuntu 18.04
Hyun Ko
hyunko is on a distinguished road
Hi all,
I am trying to build 7.0.1 in ubuntu 18.04.
I got the following messages when I run meson build.
I have installed mpi & python 3.7.1.
please give an advice for that.
Thanks.
hero@dndn64c:~/Downloads/su2-701$ ./meson.py build
git command not found. Using fall-back method to init submodules
Downloading CoDiPack '501dcf0305df147481630f20ce37c2e624fb351f'
Traceback (most recent call last):
File "./meson.py", line 71, in <module>
init_submodules('auto')
File "/home/hero/Downloads/su2-701/meson_scripts/init.py", line 85, in init_submodules
download_module(codi_name, alt_name_codi, github_repo_codi, sha_version_codi)
File "/home/hero/Downloads/su2-701/meson_scripts/init.py", line 165, in download_module
urllib.request.urlretrieve (url, commit_sha + '.zip')
File "/usr/local/lib/python3.7/urllib/request.py", line 247, in urlretrieve
with contextlib.closing(urlopen(url, data)) as fp:
File "/usr/local/lib/python3.7/urllib/request.py", line 222, in urlopen
return opener.open(url, data, timeout)
File "/usr/local/lib/python3.7/urllib/request.py", line 525, in open
response = self._open(req, data)
File "/usr/local/lib/python3.7/urllib/request.py", line 548, in _open
'unknown_open', req)
File "/usr/local/lib/python3.7/urllib/request.py", line 503, in _call_chain
result = func(*args)
File "/usr/local/lib/python3.7/urllib/request.py", line 1387, in unknown_open
raise URLError('unknown url type: %s' % type)
urllib.error.URLError: <urlopen error unknown url type: https>
hyunko is offline   Reply With Quote
Old   February 28, 2020, 02:07
Andrew
kett is on a distinguished road
Try running the following first
sudo apt install git
kett is offline   Reply With Quote
Old   February 28, 2020, 03:19
Hyun Ko
Hi kett,
Tried, but only "git command" related thing is vanished.
Still as follows.
Old   February 28, 2020, 03:45
Hyun Ko
I tried to use git command.
>>git clone https://github.com/su2code/SU2.git
meson & ninja worked.
But, when I run a simulation with mpirun or parallel_computation.py,
I got the same output messages as the number of cores I used.
And finally ABORTED!!!. see the following messages.
For single core run, it works. but fails in parallel runs.
Thanks in advances.
======= screen outputs ============================================
------------------- Geometry Preprocessing ( Zone 0 ) -------------------
Three dimensional problem.
3303775 grid points.
7133068 volume elements.
mpirun noticed that process rank 58 with PID 0 on node dndn64c exited on signal 6 (Aborted).
File "/usr/local/bin/parallel_computation.py", line 106, in <module>
main()
File "/usr/local/bin/parallel_computation.py", line 57, in main
options.compute )
File "/usr/local/bin/parallel_computation.py", line 84, in parallel_computation
info = SU2.run.CFD(config)
File "/usr/local/bin/SU2/run/interface.py", line 112, in CFD
run_command( the_Command )
File "/usr/local/bin/SU2/run/interface.py", line 292, in run_command
raise exception(message)
RuntimeError: Path = /home/hero/test/,
Command = mpirun -n 64 /usr/local/bin/SU2_CFD config_CFD.cfg
SU2 process returned error '134'
terminate called after throwing an instance of 'St9bad_alloc'
what(): std::bad_alloc
terminate called after throwing an instance of 'std::bad_alloc'
Old   February 28, 2020, 03:50
Hyun Ko
Followings are the messages when I used meson & ninja
hero@dndn64c:~/Downloads/SU2$ ./meson.py build
Initialize submodule /home/hero/Downloads/SU2/externals/codi using git ...
Submodule 'externals/codi' (https://github.com/scicompkl/CoDiPack) registered for path 'externals/codi'
Cloning into '/home/hero/Downloads/SU2/externals/codi'...
Submodule path 'externals/codi': checked out '501dcf0305df147481630f20ce37c2e624fb351f'
Initialize submodule /home/hero/Downloads/SU2/externals/medi using git ...
Submodule 'externals/medi' (https://github.com/SciCompKL/MeDiPack) registered for path 'externals/medi'
Cloning into '/home/hero/Downloads/SU2/externals/medi'...
Submodule path 'externals/medi': checked out 'edde14f9ac4026b72b1e130f61c0a78e8652afa5'
Initialize submodule /home/hero/Downloads/SU2/externals/meson using git ...
Submodule 'externals/meson' (https://github.com/mesonbuild/meson) registered for path 'externals/meson'
Cloning into '/home/hero/Downloads/SU2/externals/meson'...
Submodule path 'externals/meson': checked out '0435691e83fb7172e2a9635d2eb32d5521089916'
Initialize submodule /home/hero/Downloads/SU2/externals/ninja using git ...
Submodule 'externals/ninja' (https://github.com/ninja-build/ninja) registered for path 'externals/ninja'
Cloning into '/home/hero/Downloads/SU2/externals/ninja'...
Submodule path 'externals/ninja': checked out '2d15b04e411229cb902332957281622119025e77'
ninja executable not found. Building ...
bootstrapping ninja...
warning: A compatible version of re2c (>= 0.11.3) was not found; changes to src/*.in.cc will not affect your build.
wrote build.ninja.
bootstrap complete. rebuilding...
[29/29] LINK ninja
The Meson build system
Version: 0.52.999
Source dir: /home/hero/Downloads/SU2
Build dir: /home/hero/Downloads/SU2/build
Build type: native build
Project name: SU2
Project version: 7.0.1
C compiler for the host machine: cc (gcc 7.4.0 "cc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0")
C linker for the host machine: GNU ld.bfd 2.30
C++ compiler for the host machine: c++ (gcc 7.4.0 "c++ (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0")
C++ linker for the host machine: GNU ld.bfd 2.30
Host machine cpu family: x86_64
Host machine cpu: x86_64
Program python3 found: YES (/usr/local/bin/python3)
Run-time dependency MPI for c found: YES
Run-time dependency MPI for cpp found: YES
Message: Extracting boost ...
Message: -------------------------------------------------------------------------
| ___ _ _ ___ |
| / __| | | |_ ) Release 7.0.1 "Blackbird" |
| \__ \ |_| |/ / |
| |___/\___//___| Meson Configuration Summary |
Option Value
TecIO: true
CGNS: true
AD (reverse): false
AD (forward): false
Python Wrapper: false
Intel-MKL: false
OpenBlas: false
PaStiX: false
Please be sure to add the $SU2_HOME and $SU2_RUN environment variables,
and update your $PATH (and $PYTHONPATH if applicable) with $SU2_RUN
Based on the input to this configuration, add these lines to your .bashrc file:
export SU2_RUN=/usr/local/bin
export SU2_HOME=/home/hero/Downloads/SU2
export PATH=$PATH:$SU2_RUN
export PYTHONPATH=$PYTHONPATH:$SU2_RUN
Use './ninja -C build install' to compile and install SU2
Build targets in project: 11
Found ninja-1.9.0.git at /home/hero/Downloads/SU2/ninja
hero@dndn64c:~/Downloads/SU2$ ./ninja -C build install
ninja: Entering directory `build'
[84/389] Compiling C object 'externals/cgns/d6f0b8a@@cgns@sta/cgns_io.c.o'.
../externals/cgns/cgns_io.c: In function ‘cgio_check_file’:
../externals/cgns/cgns_io.c:606:5: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
fread (buf, 1, sizeof(buf), fp);
[102/389] Compiling C object 'externals/cgns/d6f0b8a@@cgns@sta/adf_ADF_interface.c.o'.
../externals/cgns/adf/ADF_interface.c: In function ‘ADF_Database_Valid’:
../externals/cgns/adf/ADF_interface.c:1022:5: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
fread (header, sizeof(char), 32, fp);
[158/389] Compiling C object 'externals/metis/15213e7@@metis@sta/GKlib_gkregex.c.o'.
../externals/metis/GKlib/gkregex.c: In function ‘init_dfa’:
../externals/metis/GKlib/gkregex.c:3434:7: warning: implicit declaration of function ‘strcasecmp’ [-Wimplicit-function-declaration]
if (strcasecmp (codeset_name, "UTF-8") == 0
[388/389] Installing files.
Installation failed due to insufficient permissions.
Attempting to use polkit to gain elevated privileges...
Installing SU2_CFD/src/SU2_CFD to /usr/local/bin
Installing SU2_DOT/src/SU2_DOT to /usr/local/bin
Installing SU2_DEF/src/SU2_DEF to /usr/local/bin
Installing SU2_GEO/src/SU2_GEO to /usr/local/bin
Installing SU2_MSH/src/SU2_MSH to /usr/local/bin
Installing SU2_SOL/src/SU2_SOL to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/continuous_adjoint.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/compute_uncertainty.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/finite_differences.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/mesh_deformation.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/parallel_computation.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/parallel_computation_fsi.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/package_tests.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/shape_optimization.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/merge_solution.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/set_ffd_design_var.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/compute_polar.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/compute_multipoint.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/discrete_adjoint.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/direct_differentiation.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/fsi_computation.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/SU2_CFD.py to /usr/local/bin
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/__init__.py to /usr/local/bin/SU2
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/eval/design.py to /usr/local/bin/SU2/eval
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/eval/functions.py to /usr/local/bin/SU2/eval
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/eval/gradients.py to /usr/local/bin/SU2/eval
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/eval/__init__.py to /usr/local/bin/SU2/eval
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/config.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/config_options.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/data.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/filelock.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/redirect.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/state.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/tools.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/historyMap.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/io/__init__.py to /usr/local/bin/SU2/io
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/mesh/adapt.py to /usr/local/bin/SU2/mesh
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/mesh/tools.py to /usr/local/bin/SU2/mesh
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/mesh/__init__.py to /usr/local/bin/SU2/mesh
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/opt/project.py to /usr/local/bin/SU2/opt
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/opt/scipy_tools.py to /usr/local/bin/SU2/opt
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/opt/__init__.py to /usr/local/bin/SU2/opt
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/adaptation.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/adjoint.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/deform.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/direct.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/interface.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/merge.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/geometry.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/projection.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/run/__init__.py to /usr/local/bin/SU2/run
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/bunch.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/filter_adjoint.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/lhc_unif.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/misc.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/mp_eval.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/ordered_bunch.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/ordered_dict.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/plot.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/polarSweepLib.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/which.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/switch.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/SU2/util/__init__.py to /usr/local/bin/SU2/util
Installing /home/hero/Downloads/SU2/SU2_PY/FSI/__init__.py to /usr/local/bin/FSI
Installing /home/hero/Downloads/SU2/SU2_PY/FSI/FSIInterface.py to /usr/local/bin/FSI
Installing /home/hero/Downloads/SU2/SU2_PY/FSI/PitchPlungeAirfoilStructuralTester.py to /usr/local/bin/FSI
Installing /home/hero/Downloads/SU2/SU2_PY/FSI/io/__init__.py to /usr/local/bin/FSI
Installing /home/hero/Downloads/SU2/SU2_PY/FSI/io/FSI_config.py to /usr/local/bin/FSI
Installing /home/hero/Downloads/SU2/SU2_PY/FSI/util/__init__.py to /usr/local/bin/FSI
Installing /home/hero/Downloads/SU2/SU2_PY/FSI/util/switch.py to /usr/local/bin/FSI
Old   February 28, 2020, 21:44
Default Solved
Hyun Ko
1. The problem is related to mpirun.
when I check the mpirun, it was openmpi version mpirun.
So I changed it into mpich version mpirun.
2. I suggest to use careful when apply mpi related dependency.
Best
Old   March 15, 2020, 09:38
Umut Can
Umuteng is on a distinguished road
wrote build.ninja.
[29/29] LINK ninja
Version: 0.52.999
Project name: SU2
| ___ _ _ ___ |
| \__ \ |_| |/ / |
Option Value
TecIO: true
CGNS: true
AD (reverse): false
AD (forward): false
Intel-MKL: false
OpenBlas: false
PaStiX: false
I think it is related to permission. It actually gives you "Installation failed due to insufficient permissions." error. Be a superuser, try it again. it should help
Umuteng is offline   Reply With Quote
Old   March 16, 2020, 04:37
Hyun Ko
Thank you Umuteng.
I have tried already about the superuser related stuff.
The main reason of "multiple outputs for parallel run" was related to mpirun.
I have cleared mpirun related error with using MPICH version mpirun.
Thanks.
[OpenFOAM.org] Install OpenFOAM-2.4.0 in Ubuntu 18.04? luckyraymond OpenFOAM Installation 10 April 26, 2023 13:26
[Other] Qt5, OpenFOAM-7 and -v1906, and Ubuntu 18.04 gcengineer OpenFOAM Installation 9 June 22, 2020 18:45
Could SU2 be run in parallel on windows without using Ubuntu BASH? angupraveen SU2 Installation 0 May 24, 2019 06:52
[OpenFOAM.org] OpenFOAM 3.0.1 in Ubuntu 18.04 jlr OpenFOAM Installation 4 January 3, 2019 12:57
Parallel Build for SU2 on Ubuntu McAero SU2 11 October 28, 2018 17:53
