January 5, 2021, 14:37 |
ninja fails while installing SU2 v7.0.8
While running ninja:
./ninja -C build install I'm getting the following error message: ninja: Entering directory `build' [359/445] Compiling C++ object SU2_CFD/src/libSU2core.a.p/solvers_CIncNSSolver.cpp.o FAILED: SU2_CFD/src/libSU2core.a.p/solvers_CIncNSSolver.cpp.o c++ -ISU2_CFD/src/libSU2core.a.p -ISU2_CFD/src -I../SU2_CFD/src -I../externals/CLI11 -I../externals/cgns/adf -IGKlib -I../externals/metis/libmetis -I../externals/parmetis/include -I../externals/parmetis/libparmetis -Iexterciompisrc -ICommon/src -I../Common/src -I/usr/include/openmpi-x86_64 -pipe -D_FILE_OFFSET_BITS=64 -std=c++11 -Oecated-declarations -Wno-non-virtual-dtor -DHAVE_CGNS -DNDEBUG -DHAVE_MPI -DHAVE_METIS -DHAVE_PARMETIS -DHAVE_T2_CFD/src/libSU2core.a.p/solvers_CIncNSSolver.cpp.o.d' -o SU2_CFD/src/libSU2core.a.p/solvers_CIncNSSolver.cpp.o In file included from ../SU2_CFD/src/solvers/../../include/solvers/../fluid/../../../Common/include/containers/ from ../SU2_CFD/src/solvers/../../include/solvers/../fluid/../../../Common/include/containers/ from ../SU2_CFD/src/solvers/../../include/solvers/../fluid/../../../Common/include/CConfig.hpp from ../SU2_CFD/src/solvers/../../include/solvers/../fluid/CFluidModel.hpp:33, from ../SU2_CFD/src/solvers/../../include/solvers/CSolver.hpp:43, from ../SU2_CFD/src/solvers/../../include/solvers/CFVMFlowSolverBase.hpp:31, from ../SU2_CFD/src/solvers/../../include/solvers/CIncEulerSolver.hpp:30, from ../SU2_CFD/src/solvers/../../include/solvers/CIncNSSolver.hpp:30, from ../SU2_CFD/src/solvers/CIncNSSolver.cpp:28: ../SU2_CFD/src/solvers/../../include/solvers/../fluid/../../../Common/include/containers/../parallelization/vec ../SU2_CFD/src/solvers/../../include/solvers/CFVMFlowSolverBase.inl:1306:16: required from here ../SU2_CFD/src/solvers/../../include/solvers/../fluid/../../../Common/include/containers/../parallelization/vec alignas(Align) Scalar x_[N]; ^ [361/445] Compiling C++ object SU2_CFD/src/libSU2core.a.p/solvers_CIncEulerSolver.cpp.o ninja: build stopped: subcommand failed. Redhat version 7 Update 4 GCC - 4.8.5 Kindly help Last edited by Grim; January 5, 2021 at 21:21. |
January 5, 2021, 17:51 |
Pedro Gomes
Rep Power: 13 |
It is usually a compiler problem, you need a compiler with complete c++11 support, try gcc 5 or newer.
January 9, 2021, 15:18 |
Thank you very much. I installed GCC 7.3.0 and it worked like a charm.
SU2 paralllel Build from source ninja failed on ubuntu 18.04 | steadyman | SU2 Installation | 4 | July 4, 2020 18:21 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 22:38 |
Error Installing SU2 6.0.0 | fazaghifari | SU2 Installation | 6 | March 1, 2019 08:07 |
Installing SU2 v5 for Parallel Computations | McAero | SU2 Installation | 4 | December 10, 2017 17:02 |
